ATE blue from January
During the winter, I was bored; so I completely flushed my brake system with ATE blue. The car sat in the garage ever since, not even a test drive.
now, it's almost May, and I have a track event coming up.
Do you think the fluid is still good ??
I figure it got to be as good as any fluid in a plastic container, since the master is plastic.
what ya think ????
what ya think ????
Hmmmm...1 hour (or less) of your time. $10 worth of fluid. Peace of mind.....
It's probably ok. However I'd bleed it, but that's just me
Oh God, not again?!?!?!?!?!?!?!??! I'm starting to think some guys start threads like this just to see if anybody is gullible enough to fall for the question.
OK I'll bite...... the DAMN fluid is fine and 5 years from now it will be fine and probable five years after that will be fine. It's freakin' brake fluid.
And yes I know all about water absorption, blah, blah, blah,
Rick
Rick
appearently you never boiled fluid on the track.
Rick
Rick
what ya think ????
what ya think ????
I'd run it! I bring fluid to the track, if there were an issue I would change it there, it's quick to do!
My vote is also "it's fine but bleed them".
Just ran Mid-Ohio last weekend on year-old superblue, no boiling, no problems...and yes I use the brakes hard. Got mild fade (with Brembo big brake kit) on one of the faster sessions, but not due to fluid boiling, just hot pads. They came right back next session without a bleed.
I did boil fluid prior to switching to Super Bluea couple years ago. I now purge the calipers every 3 track days. With him having put no heat to the fluid in the calipers there's no need to even bleed.
I've found 8-10 pumps to the calipers every 3 track days keeps a constant supply of good fluid in the system.
I'm really wondering if I should change the air in my tires. It's been in there for over a year and smells stale.
Rick
Rick
