C5 lap belt mounts
Old 04-29-2007, 08:29 PM
CF6873
CF6873's Avatar
Default C5 lap belt mounts
Is anybody using the RD lap belt kit? It appears to be brackets that attach to the rear seat mounting bolts. Is this mounting location strong enough?
http://www.r-dracing.com/cb3.JPG
Thanks,
Craig
Old 04-29-2007, 09:08 PM
Snidley
Snidley's Avatar
I have the R&D bar in my coupe, and used the bolt for harness mounting for a couple of times at the track. Everything tightened up just fine, but changed to Brey-Krause mounts to be able to remove the belts easily. Of course, I never "tested" the mount to the "extreme."
Old 04-29-2007, 10:18 PM
TommyBoy72
TommyBoy72's Avatar
I've been eyeballing this since my other order has been delayed for weeks for a different product. I just would like to see a pic of how a 3" lap belt would mount to it since it looks like it is only big enough for anti-submarine belts.
Old 04-30-2007, 09:35 PM
Webz
Webz's Avatar
To C5 lap belt mounts
Quick Reply: C5 lap belt mounts
