LS2 additional 1/2 quart oil?
Old 05-01-2007, 10:53 AM
z060ntrack
z060ntrack's Avatar
Default LS2 additional 1/2 quart oil?
Is it still recomended to add (overfill) 1/2 quart of oil for track events in an LS2?
Old 05-01-2007, 12:41 PM
MattW_VA
MattW_VA's Avatar
St. Jude Donor '07
Common practice dictates 1 quart over, this is also stated in the owners manual.
Old 05-01-2007, 01:35 PM
AFVETTE
AFVETTE's Avatar
Yes.
From page 4-18 in the 2006 Owners Manual
Racing or Other Competitive Driving
See your warranty book before using your vehicle for
racing or other competitive driving.
Notice: If you use your vehicle for racing or other
competitive driving, the engine may use more
oil than it would with normal use. Low oil levels can
damage the engine. For information on how to
add oil, see Engine Oil on page 5-16.
Z06 Only: Be sure to check the oil level often during
racing or other competitive driving and keep the
level at or near the upper mark that shows the
proper operating range on the engine oil dipstick.
Except Z06: Be sure to check the oil level often
during racing or other competitive driving and keep
the level at or near 1 quart (1 L) above the upper
mark
that shows the proper operating range on the
engine oil dipstick. After the competitive driving,
remove excess oil so that the level on the dipstick is
not above the upper mark that shows the proper
operating range.
Vehicles with the Z51 performance package have
greaseable outer ends on both of the rear toe-links.
Under normal use, lubrication should be performed as
described in the maintenance schedule. See Scheduled
Maintenance on page 6-4 and Recommended Fluids and
Lubricants on page 6-12. If you use the vehicle for racing,
lubrication should be performed at the end of each racing
day. See your dealer for lubrication and make sure any
needed repairs are made at once. Proper procedures for
performing these services can be found in the service
manual.
Tom
To LS2 additional 1/2 quart oil?
Quick Reply: LS2 additional 1/2 quart oil?
