Hoosier tire fitment question
OK... were did they go?
I've been running Hoosier 305-30 x 18 on stock rims on the back of my '02 Z. I went to the hoosier and tire rack site and they are no longer listed... ugh!
Has anyone fit up Hoosiers R6 315/30ZR18 or 295/30ZR18's in the rear? will the 315's fit?
tanks
dan
tanks
dan
Looking at that myself for my GY slicks vs 305 they will fit. I will run them in the front and 335 rear.
tanks
dan
tanks
dan
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
See the specs for appropriate rim width.. 295's are fine on a 9 1/2" rim, 315's are perfect for a 10 1/2" rim.
For those running CCW's do you run 315 all around or go smaller on the front? I have a set I got from a friend. Fronts are 18x11 with 11.5" wide goodyears and rears are 18x12 with 12.5" goodyears. I have never ran them, but when I do I am not sure if I should go 315 hoosiers all around or just in back and 295's in the front.
thanks,
-V
thanks,
-V
