Fellas... oem/napa rotors... how "heat checked" is too much? When to trash?
Old 05-09-2007, 07:15 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Fellas... oem/napa rotors... how "heat checked" is too much? When to trash?
Installing some fresh calipers right now... I have one set of new napas, one set w/ one VIR HPDE on them, and another w/ 2.
The set w/ 2 has visible heat chracks in the disc surface, while the others do not (of course the new ones don't).
Are they trash?
Common sense says go ahead and install the new ones for this year, then keep the better set as backups and trash the heat checked ones.
How far do you go? The checking doesn't go to the edge of the rotor yet. Any good metric?
Old 05-09-2007, 07:45 PM
freefall
freefall's Avatar
That doesn't look like much - but that first pic is awful, so it's hard to say for sure! I'd probably use those again...what pads are you running?
Old 05-09-2007, 08:32 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,394 Likes on 747 Posts
I asked the same question about a month ago:
http://forums.corvetteforum.com/show....php?t=1673518
Understand that I mainly autocross with just one or two DEs a year. My rotors have been as heat checked as in your 2nd photo for two years with no real change.
HTH, and have a good one,
Mike
Old 05-09-2007, 08:54 PM
Oyishdog
Oyishdog's Avatar
look fine to me
Old 05-09-2007, 09:43 PM
CHJ In Virginia
CHJ In Virginia's Avatar
The rotor in the second picture has plenty of life in it. I would run it at least a couple of more days before trashing. Visually check it after each run group session. If you feel concerned, save them for spares and use new. At $30.00 each it is not a big investment in new.
Old 05-09-2007, 09:44 PM
TmillerC5
TmillerC5's Avatar
St. Jude Donor '08
Wait till the have cracks, then is boat anchor time.
Old 05-09-2007, 09:49 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
run them till they look like dry mud in the desert They look good for a few days as long as your driving not me . They are fine for a few days. Check after they cool when you come in and roll the car so crack isn't hidden behind the spoke. Better taking picture in bright light outside so they is no flash
Old 05-09-2007, 11:36 PM
Cobra4B
Cobra4B's Avatar
Thanks... I'm installing the brand new ones then keeping the one full set of spares, then these as my secondary front spares.
I had the brakes fully off anyway... dumb not to put the freshest ones on the car.
I'll be running Carbotech XP12/XP10's vs. the Wilwood H's I had before so they should last longer.
Old 05-10-2007, 07:04 AM
AU N EGL
AU N EGL's Avatar
Brian I would run those one more weekend. But then again I always keep a spare set too.
But if you are changing those, make these your spare rotors. After all they are seasoned
Old 05-10-2007, 10:17 AM
Cobra4B
Cobra4B's Avatar
Yes... they are rather "seasoned". I'm installing the new ones, then keeping the fresher set as my main spares and the pictured fronts as my backup spares. The back pair from the "lighter used" set are grooved and I'll chuck those.
So that make one full spare set and one more set of spare fronts... should be good to go for awhile
Old 05-10-2007, 12:20 PM
undertaker
undertaker's Avatar
Location: ECS : WTF did you break now and HTF did you break it this time
I run mine till they crack the whole way through, I'd barely even call those cracks, they're more like grains or somethin....when you crack a rotor you'll know it, hell I still drove the car around normally on the street for 20-30 miles with a pulled back last week before I had time to swap them.....I just wouldn't track a cracked rotor but its driveable in a jam.
To Fellas... oem/napa rotors... how "heat checked" is too much? When to trash?
Quick Reply: Fellas... oem/napa rotors... how "heat checked" is too much? When to trash?
