Wheels for A 315/35/17
Old 05-29-2007, 08:32 PM
R Mackow
R Mackow's Avatar
Default Wheels for A 315/35/17
I would like to use Hoosier "A" tire in 295/35/17 F and 315/35/17 R on my C5 for SCCA autoxing. I believe I would be in class ASP(?). Anybody know what wheel size to use? I've been told the C4 wheels 10" F and 11"R w/the Grand Sport off sets would do the trick. Will Camaro wheel work? What are the req'd. specs. for the offset/setback F and R?
Am I on the right track here? (Not intended to be a pun.)
Old 05-30-2007, 10:49 AM
UstaB-GS549
UstaB-GS549's Avatar
17X11 rear GS wheels have 50mm offset. 315 fits nicely but sticks out a little.
I think 17x9.5 has 54mm or 58mm offset
Old 05-30-2007, 02:58 PM
Solo2GS
Solo2GS's Avatar
St. Jude Donor '07
I run the GS 17 X 11 wheels on on all 4 corners w/ 315's on my C5 FRC with no problem. They stick out a tad, but no rubbing issues.
Old 05-30-2007, 03:07 PM
TedDBere
TedDBere's Avatar
Stock Z06 sizes. 9.5 17s and 10.5 18s will work. Nevermind, I see you want 17s on the rear.
Old 05-30-2007, 09:35 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,911 Likes on 5,325 Posts
On my car there is one rubbing issue with the front 17 x 11s. The rims touch the control arms on tight turns and do a nice job of removing the balance weights.
Bill
To Wheels for A 315/35/17
Quick Reply: Wheels for A 315/35/17
