Aftermarket exhaust, Trailer hitch, C5-Z06
So the title says it. I'm looking for an aftermarket exhaust system. It must clear a trailer hitch on my 02-Z06. Anyone got this setup that can tell me for sure which ones clear?
The stock Ti system clears perfectly. Supposedly any aftermarket system made exactly to stock specs would work. I figured I'd post it here then cross post to C5 Tech. I know I'm not the only guy towing a utility trailer with tools and race tires to the track.
I had a hitch and B&B Bullets (dual tip) on my 02 Z06. I wouldn't go recommend that setup. The bolt heads were right at the high point of the tips. It took a lot of adjusting to avoid rubbing. I actually went back to stock because of it.
Thanks guys! Any other folks please chime in.
Brian the Borla Stingers are a bit over the top for me. I couldn't live with that everyday. Nice muscle car sound though. Maybe their system with real mufflers will have the same tip layout.
Beerkat please do post back on the Corsa fit. I am thinking maybe Corsa because they do such a good job with resonance removal.
Red Guts - B&B is on my list. I really like their Route 66 with Speedway tips. I left them message and so far one vendor is trying to tell me that all B&B systems fit around the hitch. That's why I asked. Most of these aftermarket vendors do not build their exhaust to sit identical to the factory, regardless of their claims...
FYI: Titanium mufflers crack! And sometimes they make a hell of mess out of the rear end of your car. I'm going SS and will deal with a noisier car.
Location: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
I have the B&B quad tips and they clear the hitch (just installed this past Monday)....There is some rubbing on the safety hooks, but I can relocate those to the back of the hitch if it gets annoying..
Adam
Adam
CI 3-5-6-7-8 Veteran
They're quite loud w/ the cam and headers, but the Z06 is my toy as I have a nice DD so it's fine w/ me. I just got done driving it to Bowling Green, KY and back for the Cruise In and w/ the partition in and luggage in the trunk it's completely fine for me w/ minimal drone.
Stock Ti's fit, Dual tip B&B Bullets fit if hung very low but had a tendency to rub and vibrate-I wouldn't recommend them despite the great exhaust sound. Corsa with pro tips fit great with absolutely no issues and no resonance. That is my experience with my 2003 Z06.
So far I'm leaning towards B&B Route 66 with Speedway tips. A bit more tame and the tips sit way to the side according to the pictures I've looked at.
Just an update.
Beerkat - Corsa does fit with the trailer hitch. I got the Pace Car version with Classic tips. Haven't got to drive the car much but on a couple of test rides. No contact between the pipes or mufflers on the hitch anywhere at all.
Cobra4B - Yes those Corsa mufflers ARE heavy. I do like the sound though. Tame at cruise but muscle car V8 sound under acceleration. No resonance and tolerable without a partition in place. With the partition I suspect they will be fine for daily driving and highway cruising. Nice sound under full acceleration. Should sound good on track.
I have a little bit of a clearance issue with the Corsa. On a bumpy road I can hear it hit but I can live with it. I am going to try my trailer this weekend when I go to Rockingham with NASA-SE.
