Goodyear F1 GS-CS Pressure
What's a good cold, or target hot, pressure to use for GY F1 GS-CSs. My alignment is only set to 1.50 camber if that has much bearing on the correct pressure.
OK, if not for the GS-CSs, generally what tire pressure do stickies run. More or less than street tread? Any starting point would help.
I used to target for around 40psi Hot, but recently I've been targeting for a lower pressure of 36 front and 35 rear, Hot. I feel the lower pressure works better for grip and balance.
Jim
Jim
I usually started at 30 psi cold and kept them @ 40 but think a little lower target is better (for GY GSCS)
