When are Radiator hoses too old for HPDE?
Old 06-01-2007, 01:57 PM
sothpaw2
sothpaw2's Avatar
Default When are Radiator hoses too old for HPDE?
One of the last times I tracked my C4, it blew a Radiatior hose.
I had asked the mechanic to look them over and he said they were good, so now I realize you just have to do it on age (well, I realized it then too but the car was used so I didn't know if they had been replaced).
Obviously10 years old is an old hose, but where do you draw the line? Is it wise to bring a main rad hose with you at any age/mileage?
Old 06-01-2007, 03:18 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I think the 2 large hoses, as well as a spare belt, would certainly be great additions to any parts box. However, they seem to be really durable. My 97' still has the hoses that were on it when I got it, and they look like new. They may have been changed by a prior owner, or GM may be using good stuff, but I don't see any reason to change them.
Old 06-01-2007, 03:20 PM
ErnieN85
ErnieN85's Avatar
GM says EPDM hoses are good for the life of the car.
I believe it's the stuff Goodyear uses in their Himiler hoses. just seems to last & last
Old 06-01-2007, 04:57 PM
sothpaw2
sothpaw2's Avatar
Well, I can tell you the stuff they had in the fall of 1992 did not last forever and blew under the stress of hard track use on the 2nd day. This was a 12+ year old hose at the time.
When did they switch material?
I guess it is not common at least on C5's to blow a hose? In that case I should not worry too much.
Old 06-01-2007, 05:01 PM
TedDBere
TedDBere's Avatar
I had mine pop off the top of the radiator 2 events ago. It looked like it was never put on all the way and just worked itself off after 20k miles. Nothing wrong with the clamp and nothing wrong with the hose. Really strange.
Old 06-01-2007, 07:02 PM
ErnieN85
ErnieN85's Avatar
Yes, I put Goodyear HiMiler on my 1985,
GM changed with the C5 so I'm good to go with my 02 (for a while) I thinh I'll change around 100,000 or so
To When are Radiator hoses too old for HPDE?
Quick Reply: When are Radiator hoses too old for HPDE?
