C4 racer, showing ducts in lights.
Old 06-02-2007, 06:13 PM
Aardwolf
Aardwolf's Avatar
Default C4 racer, showing ducts in lights.
There is a C4 racer for sale on Ebay. Someone asked about having ducts in the front lights so I thought I'd pass this on.
http://cgi.ebay.com/ebaymotors/ws/eB...m=160123458817
If the link gets deleted it is #160123458817
BTW, bonus girl picture.
Old 06-02-2007, 10:40 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
is it package deal?
Old 06-03-2007, 08:26 AM
94ZR1#444
94ZR1#444's Avatar
Is the owner on this forum or has anyone here seen/heard this car run at BW? Is this Evan's old car? Thanks
Mark
Old 06-03-2007, 12:06 PM
Sidney004
Sidney004's Avatar
I am sure it is Evan's car. Alan Blaine is a top notch fabricator around here, he knows what he is doing.
Old 06-03-2007, 12:24 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Thought I saw the, um, car on the forum before
Old 06-03-2007, 02:50 PM
ZBRA
Support Corvetteforum!
ZBRA's Avatar
If that's his better half, he's doing something right. Just damn!
Old 06-04-2007, 12:07 AM
Slalom4me
Slalom4me's Avatar
There is quite a strong resemblance. Click the image to go
to a gallery on WebShots.
A description from '05
FS: SCCA/NASA C4 RACECAR! 2004 Buildup (09-19-2005)
My vote is that the lady is a model, hired by the seller, californiaclassix,
for obvious reasons - she is very good at what she does.
Old 06-04-2007, 07:36 AM
eogel
eogel's Avatar
Default C4 brake ducts
Here are three implementations of front-end brake ducts on the same car.
1) Although this implementation of headlight ducts is only applicable to a dedicated track/race car, it may be of interest to some. I designed and built these.
2) The lower lights have been removed and an air duct was fabricated to direct this air to a hose going to the rotor. The interior is typically painted black, but road debris from racing chips it off down to the fiberglass.
3) The turn signal lights are removed and a duct captures air there for the brakes.
Sorry, no eye candy in the pictures this time.
Old 06-04-2007, 04:47 PM
ScaryFast
ScaryFast's Avatar
Are they for sale?
What did you do for the hood louvres? Can you take another photo higher on the hood?
THX!
Old 06-04-2007, 04:48 PM
ScaryFast
ScaryFast's Avatar
Oh, and how do I get the damn turn signal lights out of the bumper? I can't seem to free them up. Do I have to take the whole damn bumper off?
Old 06-04-2007, 04:52 PM
MUKAK
MUKAK's Avatar
yammy!!
Old 06-04-2007, 09:00 PM
eogel
eogel's Avatar
Responses to above questions.
Are they for sale?
Answer: Did not intend to make them for sale, just a one off for my racecar to get air to the brakes.
Answer: No hood louvers on the car. It is a stock C4 hood.
Looking to put a lighter hood on later.
Answer: Did not take the bumper off. Keep in mind this is a
dedicated racecar, so the entire headlight mechanism is
removed. This gives easy & direct access to the lights.
They have been off for a while, so I don’t recall the steps,
but think they were bolted in. See if you can access them
in a similar manner you would change the bulb.
Old 06-04-2007, 11:58 PM
96GS#007
96GS#007's Avatar
Received 1,743 Likes on 1,051 Posts
Front bumper cover has to come off if you want to keep the turn signal lights intact (and it assumes the rest of the front end is stock). Otherwise, use of a more specialized tool set...hammer and screwdriver...will pop 'em right out
Old 06-05-2007, 04:25 PM
ScaryFast
ScaryFast's Avatar
There is a metal clip thing in there that seems to prevent this. There is absolutely nothing in the way (on the driver side the headlight, CC bubble, AIR pump, and horn are long gone, passenger side has only the coolant overflow tank) so I have access to them, they just won't pop out...
I'll look again tonight while I'm in there.
Old 06-05-2007, 04:57 PM
Vetracr
Vetracr's Avatar
Evan can answer the question but I saw Evan building his car in his shop. I was impressed with the fabrication work was doing including all the fiberglass work. Alan Blaine is a top notch fabricator (and racer). If he built this car it'll fly.
Larry
Old 06-06-2007, 12:05 AM
96GS#007
96GS#007's Avatar
I recall the lights having a couple tabs with bolts thru them that go in from the front. I'm going from memory, but that's what my foggy brain recalls.
The hammer and screwdriver was a joke...beat/pry them out
To C4 racer, showing ducts in lights.
Quick Reply: C4 racer, showing ducts in lights.
