Best Tunnel Plate for a FRC?
Old 06-03-2007, 11:06 PM
ForceFedC5
ForceFedC5's Avatar
Default Best Tunnel Plate for a FRC?
Hello,
I'm curious from people who have them.
Which one did you buy?
Are you happy with it?
Was there a noticable difference in car "feel" & interior heat?
Thanks in advance!
Old 06-04-2007, 07:55 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,386 Likes on 742 Posts
On an FRC you'll feel next to nothing from a tunnel plate; the chassis is really stiff as is from the factory.
Can't say anything about the heat aspect of it, but my stock hardtop doesn't have any problems with heat from the tunnel. LT headers may make a difference, though.
If I wanted a thermal barrier I'd seriously consider getting my stock plate coated before I'd put on a heavier aftermarket plate.
HTH, and have a good one,
Mike
Old 06-04-2007, 08:34 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
OEM plate.
Old 06-04-2007, 08:49 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
I have one that forum member IVO made about 3 years ago when they were first comming out at outrageous prices. It's 1/4" aluminum and just like the ones you can buy.
Last fall I bougt the stick on thermal barrier from Elite Engineering to reflect the ambient exhaust heat.
Now the console and tunnel area stay far cooler. Comming back from CI-8 it was in the mid 90s and we were in stop/go traffic on 40-E comming through Tennessee. It did get a bit warm, but not like it used to. Under normal driving it stays cool.
Old 06-04-2007, 03:18 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
help with heat but you won't notice a difference in lap times. Stock is good spent money else where. They are a placebo affect.
To Best Tunnel Plate for a FRC?
Quick Reply: Best Tunnel Plate for a FRC?
