Here I go again.......again!
Old 06-06-2007, 12:58 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Default Here I go again.......again!
My last "new" 99,000mile motor for ST2. Upgrades (longevity) include new style rod bolts, JWIS timing chain, shimmed oil pump etc. You can see my ATI damper, Katech tensioner, heat-wrapped starter, aluminum motor mounts (solid), accusump fitting, and straps for torquing the damper. I also wrapped the rear header just to protect the wiring. Just thought it might be interesting to anyone that hasn't pulled one of these apart.
Hopefully this one will survive more than one race!
Old 06-06-2007, 01:40 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
What happened to the old motor? Did it go bye bye?
Old 06-06-2007, 01:45 PM
davidfarmer
When I ran the car at Rd Atlanta, the trans locked in 3rd gear during Sundays race. I ran the engine REALLY hot, but it never showed any signs of damage. I think I likely did some damage at that point, but it didn't show up until after race 1 at Roebling. By the time I ended the 2nd Roebling race, the exhaust was dripping oil and water and fuel, and my #8 cylinder is completely dead. I haven't pulled the heads to see what actually broke, but I figure it was at least both head gaskets plus some more major pieces (piston maybe) in #8
Old 06-06-2007, 01:46 PM
Cobra4B
Cobra4B's Avatar
You need simple green and a power washer
Old 06-06-2007, 02:28 PM
davidfarmer
this car will be luck if the PAINT gets washed, let alone anything under the hood. The INSIDE of the engine is clean.....and that's the only part that counts for me.
Old 06-06-2007, 03:31 PM
wallyman424
wallyman424's Avatar
am i the only vette in st2 that hasnt blown an engine?
why yes. yes i am.
Old 06-06-2007, 03:46 PM
Falcon
Falcon's Avatar
Originally Posted by wallyman424
am i the only vette in st2 that hasnt blown an engine, yet?
There, I fixed it for you.
Old 06-06-2007, 03:50 PM
Cobra4B
Cobra4B's Avatar
^ Jody did yours go?
Old 06-06-2007, 04:57 PM
Falcon
Falcon's Avatar
Yea, it lost part of #7 piston at VIR during the March race. It was still running with no noise, but it sure was down on power. Luckily, I still placed 2nd at the end of the race.
Old 06-06-2007, 05:47 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
why yes. yes i am.
You should be knocking on wood right now.
Randy
Old 06-06-2007, 05:50 PM
wallyman424
Randy
i'm gonna eat my words arent i.
randy, you got those 5/8 hub spacers in stock? can i run spacers up front and nothing out back?
Old 06-06-2007, 06:05 PM
rasrboy
rasrboy's Avatar
why yes. yes i am.
You better knock on wood Wally!
Old 06-06-2007, 06:13 PM
wallyman424
meh, I'm making up for it with my brake problems.
Old 06-06-2007, 06:34 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
I sure do.
Randy
Old 06-06-2007, 07:11 PM
Lancer033
Lancer033's Avatar
I do...or did at least. haven't done anything since last summer.
5/8" spacer with ARP wheel studs up front, factory rear
Old 06-06-2007, 07:16 PM
wallyman424
excellent, thanks for the input. i've got the arp studs all around.
Old 06-07-2007, 12:46 AM
JVetthead
JVetthead's Avatar
Where did you get the solid motor mounts? build em?
To Here I go again.......again!
Old 06-07-2007, 01:28 AM
Cobra4B
Cobra4B's Avatar
Are you guys running your motors too lean? Not running some 100 octane to keep 7 from going lean?
Old 06-07-2007, 06:56 AM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
my sentiments
Old 06-07-2007, 08:19 AM
ScaryFast
ScaryFast's Avatar
David, did you ever need to remove the heads? I'd be curious to see some pics with them off...
Thanks!
Quick Reply: Here I go again.......again!
