C3 racers: What rate are gulstrand Big block race front springs?
Old 06-06-2007, 09:23 PM
Yellow73SB
Yellow73SB's Avatar
St. Jude Donor '07
Default C3 racers: What rate are gulstrand Big block race front springs?
I'm looking at some and I'm wondering what rate they are
Chris
I don't want to get over a 900# rate. Although I could go 1200 fronts and a 600 rear. I already have the 600 rear.
Edit: apparently they are around 860#. Perfect
Old 06-07-2007, 08:47 AM
69autoXr
69autoXr's Avatar
I thought they were closer to 1000 lb/in. Nevertheless, keep in mind that it says clearly "Springs are supplied long so the customer may tailor fit ride height, instructions included" so when you cut them they will be stiffer than what you started with.
I thought Daytonas were 860's.
Quick Reply: C3 racers: What rate are gulstrand Big block race front springs?
