Proportional valve with OEM master cylinder?
Old 06-07-2007, 12:46 PM
leadfoot2
leadfoot2's Avatar
Default Proportional valve with OEM master cylinder?
What can be done to bypass the internal bias valve in the OEM master cylinder so I can use an external proportinal valve for the rear brakes? Or is the only answer an aftermarket master cylinder?
Old 06-07-2007, 02:33 PM
yellow01
yellow01's Avatar
What year do you have?
I forget the cutoff year, others will know, but the later c5s are not proportioned in the master, they are electronically proportioned.
For the earlier years, I believe DRM sold a bias spring.
Old 06-07-2007, 02:43 PM
gkmccready
gkmccready's Avatar
DRM also has a master with a proportioning valve built-in.
http://www.dougrippie.com/drm/brake_components.htm
Old 06-07-2007, 02:56 PM
leadfoot2
leadfoot2's Avatar
It's a '94 I'm building for the track. Hoping there is a less expensive method than replacing the master cylinder. Just put a new one on it last year.
To Proportional valve with OEM master cylinder?
Quick Reply: Proportional valve with OEM master cylinder?
