Inexpensive wheels to clear 4 piston 14" Brembo front brakes
Anyone know? i need to find some inexpensive street wheels that will clear Brembo 4 piston fronts with the 14" rotor on the front of a C6.
Or if anyone knows how big of spacer is required to clear 4 piston 14" with the stock C6 front wheels?
Anybody have a set that will clear the Brembos that are for sale or trade for stock plus $.
I have 2 sets of stock wheels (1 set comp grey, 1 set silver) and tires to sell unless the Brembos will fit with a minimal spacer.
When I swiched from stock brakes to brembos, I used 0.5 inch spacer. But I have a CCW wheels.
I have a set of CCW Corsairs I use at the track and they will clear without the use of a spacer but I am looking for an inexpensive street setup. Which CCW are you using?
C5 speedline 18X10.5? On the FRONT of a C6?
I put some on the back of my C6 and they stuck out like Dumbos ears.
LOL well they do stick out some, I run the C5 Z06 rears all they way around. Oddly, after the T1 susp they rub a tad in the rear where they hadn't before. But again it's just barely...
