C5 Manual Linkage U Joint Failure
Old 06-09-2007, 06:21 PM
varkwso
varkwso's Avatar
Default C5 Manual Linkage U Joint Failure
Has anyone besides me had the small u-joint at the front of the trans, and the rear of the manual shift linkage come apart?
I just put in a new trans and the linkage u-joint at the rear came apart while returning from the gas station - luckily it was stuck in 3rd gear and I got it home. All the pieces were captured in the TT bell housing but I ordered a new one from Dal. The real bummer is the trans had to come back out again . Josh and I had it out in a little over an hour .
The car has 129,022 miles on it and many of them are road course miles. But I know there are many cars with more miles on them out there.
I am now patiently waiting for the new complete linkage to get here from GM...
Old 06-12-2007, 09:48 PM
varkwso
varkwso's Avatar
I am the only one lucky enough to have this ujoint come apart? Wow
The new rod should be here tomorrow....
Old 06-12-2007, 09:54 PM
wallyman424
wallyman424's Avatar
i've heard of a lot of things breaking on c5's, but the shifter mechanism isnt one of them.
you're a pioneer.
Old 06-13-2007, 05:22 AM
97coupechuck
97coupechuck's Avatar
yea, i know your exact feeliong, I had just installed my new tranny in 97 and got to the track, did two laps and the roll pin or dowel pin came out of the linkage, left me in 3 rd as well. I had just installed on the ground in garage, so you know i was hurtin'! I just took it direct to shop and paid, wasn't going to go thru that again. Next time i do an operation like that I'm going to get a lift installed.
Old 06-13-2007, 05:32 AM
varkwso
varkwso's Avatar
you're a pioneer.
Geez - that makes me feel special. My parts guy in Ohio said he has never ordered this part before...and he orders lots of C5 parts.
97coupechuck - I know your feeling! I wish it had been the roll pin instead of the little U joint. The car would be back together now. In the end I am way too cheap to have someone do something I can do. It is not a real fun job though and no lift makes it less enjoyable.
Old 06-13-2007, 08:09 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Makes you wonder if it might have been damaged during the trans swap. I pulled the trans once without removing the torque tube with it, and getting that shifter assembly apart is not an easy thing. I'm really surprised I didn't break anything when I did it (I just drop everything now)
Anyway, hope it is a quick and painless repair.
Old 06-13-2007, 08:34 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Never heard of that happening... you have pics of how it came apart? Did it break or did something come loose?
Old 06-13-2007, 10:19 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
ON higher mileage, or abused cars we see them loosen way up. They just become sloppy. I haven't seen one break before.
Randy
Old 06-13-2007, 10:25 AM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
i feel your pain,,i just finished installing a fresh diff ,,the dealer sent me one built on a auto case and the speedo doesn't work...now to do it over...i thought i was the only one that has the silly set backs...i'm running at the nccc convention next week..hope not having the speedometer working doesn't upset the computer to much!!
Johnny
Old 06-13-2007, 06:50 PM
varkwso
varkwso's Avatar
Randy
It has mostly been driven on weekends since we have had it. It was a driving instructors car in CA before we bought it so we knew it had been tracked. As I stated it is 129,022 miles and this is the 3rd trans that I know about (last one was under warranty at 35K).
It did not "break" - the rear u-joint was so loose it "fell apart". I had two pins and ball fall out when we separated the trans from the TT. The collar was still roll pinned to the trans. I was able to put it all back together - it will be a cold day before I reinstall that rod though
We pulled it out the first two times as one unit (TT & Trans). I installed it this last time with TT already in - I found it much easier this way. Pulling only the trans this last time let me keep the headers bolted up and the TT in also. Feeding the shift linkage was not really tough and did not bind up last time. But I am also doing this without a lift and a trans jack only.
Old 06-13-2007, 07:28 PM
LG Motorsports
Premium Supporting Vendor
LG Motorsports's Avatar
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
We run ours in the World Challenge race cars for one season then change them.
We have had one break so we don't take any chances. We put new ones in every 10 race weekends.
lou G
__________________
LG Pro LT Headers, MOST HP, MOST TORQUE
http://lgmotorsports.com/gallery/alb...no_compare.jpg
LGM http://www.LGMotorsports.com
Winner Daytona 250
22 WC Wins
"Most powerful Corvette headers on the planet"
Old 06-19-2007, 06:38 PM
varkwso
varkwso's Avatar
My new one came in on Friday after we left for Rockingham. It was amazing the difference in the new one then the original one off the car. Very tight versus floppy. We put it in today - a world of difference in the tightness of the shifter - and now I have a 6 speed with reverse instead of one forward speed. It is now at the alignment shop - but that is another post....
To C5 Manual Linkage U Joint Failure
Quick Reply: C5 Manual Linkage U Joint Failure
