acp hood and tigershark frt for heat issues
Old 06-10-2007, 10:08 AM
snitz
Support Corvetteforum!
snitz's Avatar
Default acp hood and tigershark frt for heat issues
Installed ACP air extractor hood and starcraft tigershark front to combat engine heat issues. Running sc blower on rr track hoping to lower oil/coolant temps. Also have installed Dewitts raditor and ECS alky kit. Will report back after I hit the track next week. Around turn temps generally seem approx 10 degrees lower.
note: pictured wheels are street set up only (track are ccw corsairs w pilot sport cups)
Old 06-10-2007, 07:17 PM
Short-Throw
Short-Throw's Avatar
That hood looks awesome!
These darker pics do not show how truly beautiful your car is!
Mike
Old 06-10-2007, 08:00 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
You can't get much nicer than that! Wow, beautiful!
Old 06-10-2007, 10:39 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Awesome setup! I'm running the TS facia, DRM heat extractor hood, and a Dewitts racing radiator w/ left side oil cooler also. Great look and really lets air flow through well.
Old 06-10-2007, 11:22 PM
snitz
snitz's Avatar
Thanks guys. Mike and I will be out Weds at the Autobahn. Looking forward to seeing what the oil/coolant temps are really like with the new set up.
Keeping my fingers crossed.
Old 06-11-2007, 12:07 AM
snitz
snitz's Avatar
Old 06-14-2007, 03:09 PM
snitz
snitz's Avatar
Default problem solved!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Hit the track yesterday. 87 degrees, humid. With new front and extractor hood the car, never got above 262 degrees even after 30 minute hard sessions. One additional tweak I did which lowered the oil/coolant temp about 8 degrees (see pic below). I removed the foam insulation strip that runs near the windshield to keep the end of the hood sealed(so water won't get in the engine bay). This seal doesn't allow heat to escape out of the rear of the engine bay.
Removing this seal immediately improved cooling signficantly. As for any water getting into the engine bay, that's a small price to pay with a ventilated hood.
Bottom line: I can now fully enjoy the car on the track!!
Old 06-14-2007, 03:13 PM
Cobra4B
Cobra4B's Avatar
^ You mean the rubber weatherstripping... it's not foam Congrats!
Old 06-14-2007, 03:15 PM
snitz
snitz's Avatar
Good catch. It's the weatherstripping. Really helped!
Old 06-15-2007, 07:58 AM
Snuckley
Snuckley's Avatar
Don't get fooled if you smell exhaust with the weatherstrip off when you use the HVAC on the street. I took my stripping off years ago and thought I had a header leak, as I smelled exhaust when I used the HVAC , the HVAC must suck fresh air from the base of the windshield. When I put the stripping back on last month, the exhaust problem went away. The exhaust smell was only detectable when stopped at redlights with windows up and air on the NONreccirc mode. I used to not drive the vette on hot days when I needed AC it was so annoying, then one day last month I mentioned the problem to a wiser fellow who took one look at the lack of weatherstrip and said there's your exhust smell.... .......still learning everday...
Old 06-15-2007, 08:17 AM
snitz
snitz's Avatar
Thanks. Will watch that!
To acp hood and tigershark frt for heat issues
Quick Reply: acp hood and tigershark frt for heat issues
