Can I use this for P/S hose?
Old 06-11-2007, 12:36 AM
ZBRA
Support Corvetteforum!
ZBRA's Avatar
Default Can I use this for P/S hose?
I'm having a real hard time finding 5/8 power steering hose locally. I need it for the low pressure side on my LT1. There are two very short sections that are old and in dire need of replacing. One from the P/S reservoir to the cross over pipe, and one from the crossover pipe to the pump.
Can I use this high temp oil cooler hose with P/S fluid?
http://www.pegasusautoracing.com/pro...p?Product=3290
I'm also going to be mounting a large power steering cooler instead of the small factory cooler. I'll need quite a bit of the 3/8 hose.
Old 06-11-2007, 02:31 AM
kelp
kelp's Avatar
Should be fine. Are you sick of the high temps in the PS unit? I relocated my cooler for better air flow.
Old 06-11-2007, 04:17 AM
larryfs
larryfs's Avatar
don't use 5/8" heater hose. it won't last more than 6 months.
Old 06-11-2007, 09:12 AM
c4cruiser
c4cruiser's Avatar
Is there a shop in your area that makes custom-built hydraulic hoses? Maybe a brake shop that makes up brake lines? They should have bulk hose that would be suitable for power steering use. They might even be able to fabricate the size/length that you need for the application.
Old 06-11-2007, 09:51 AM
ZBRA
ZBRA's Avatar
It's not heater hose, it's oil cooler hose. Any reason why that wouldn't work for P/S fluid?
Old 06-11-2007, 09:52 AM
ZBRA
ZBRA's Avatar
Nothing really to fabricate, no crimped ends or bends anywhere. It just a short strait section with clamps on each end. It's stock. I'll get some pics in a minute.
Old 06-11-2007, 10:06 AM
ZBRA
ZBRA's Avatar
These are the two hoses I need:
Old 06-11-2007, 11:04 AM
ZO6-Driver
ZO6-Driver's Avatar
Just use some SS braided line. Done.
Old 06-11-2007, 11:58 AM
UstaB-GS549
UstaB-GS549's Avatar
Teflon with SS won't work here. The tubes have beaded ends.
I think Pegasus hose would work fine. P/S fluid is nearly same as 10W oil, so fluid compatibility should be OK.
Old 06-11-2007, 01:09 PM
ZR1 MK
ZR1 MK's Avatar
That hose can be used for the low pressure side. The crimp clamps are better and require a crimp tool, but arent necessary.
Theres a big difference between heater hose, ss covered rubber hose and ss covered teflon hose.
Old 06-11-2007, 01:17 PM
ZO6-Driver
ZO6-Driver's Avatar
SS braided covered rubber hose will work fine.
Old 06-11-2007, 01:21 PM
Aardwolf
Aardwolf's Avatar
Braided is heavy.
Old 06-11-2007, 01:48 PM
ZO6-Driver
ZO6-Driver's Avatar
Originally Posted by Aardwolf
Braided is heavy.
Yeah that 1/4 pound will kill you.
Old 06-11-2007, 02:31 PM
ZR1 MK
ZR1 MK's Avatar
For those recommending ss covered hose, does the hose clamp go over the covering or do you pull it back?
Old 06-11-2007, 02:37 PM
ZO6-Driver
ZO6-Driver's Avatar
Don't peel it back. Wrap some good tape to hold it where you cut it and use a regular hose clamp or or some like these.
http://store.summitracing.com/partde...=ear-900303erl
Old 06-11-2007, 02:42 PM
Todd Benne
Todd Benne's Avatar
Easy fix. Call us; Classic Tube and Stopflex at 800-882-3711. Ask for Tom. Tell him I told you to call. He will set you. I am not in the office, prepping to run the Glen this weekend.
Classictube.com
Stopflex.com
Old 06-11-2007, 02:44 PM
ZR1 MK
ZR1 MK's Avatar
Got it. A way to have the ss covering protection without an fittings. Im so used to working with the an fittings, I forget about the optional and basic stuff.
To Can I use this for P/S hose?
Old 06-11-2007, 02:56 PM
Aardwolf
Aardwolf's Avatar
You can add unnecessary weight to your car if you like, many of us will not.
I don't see the gain here in using braided. It adds weight and if want to use a clamp you need to buy eight dollar a pop clamps? Ouch. Peeling it back is an extra hassle. There is a time and place for different types of hose.
The hose in the first link looks like it would work fine.
Old 06-11-2007, 03:23 PM
ZO6-Driver
ZO6-Driver's Avatar
Dude, the difference in weight between 3 feet of braided and 3 feet of rubber hose is so minute. Besides he can use 50 cent a pop clamps if he so desires. Plus it will look cool.
Old 06-11-2007, 04:08 PM
ScaryFast
ScaryFast's Avatar
ZBRA, I went through the exact same thing last week. I had replaced those joints with heater hose a year or so ago not realizing that it's different.
I looked everywhere for PS hose and found 5/8" at Autozone in bulk. I bought a foot of it and have plenty left. If you don't have Autozone nearby shoot me a PM with your address and I'll ship some.
It says power steering right on the hose...
Quick Reply: Can I use this for P/S hose?
