Alignment with Toyo RA 1 Tire
Old 06-20-2007, 12:12 PM
Z06 Bob
Z06 Bob's Avatar
Default Alignment with Toyo RA 1 Tire
I am running Toyo RA 1 tires for track days and have noticed rear tires wearing more on the outer edge. Does anyone run these? Special alignment?
Old 06-20-2007, 12:27 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
what is your alignment now. ANY tire is going to wear the outside edge with a street alignment....stickier tires moreso.
Old 06-20-2007, 01:33 PM
C6400hp
C6400hp's Avatar
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
If you can get about 1 deegree of negative camber into the rear it should even out.
I have about one degree negative in back and run RA1's with even wear on back.
Old 06-20-2007, 04:46 PM
dmiz0420
dmiz0420's Avatar
I'm maxed out at .8 in the rear,
What camber do you run in the front?
Old 06-20-2007, 08:13 PM
C6400hp
C6400hp's Avatar
-1.3 to -1.4
Old 06-20-2007, 09:15 PM
Z06 Bob
Z06 Bob's Avatar
I am running stock alignment.
Old 06-20-2007, 09:36 PM
ajderzie
ajderzie's Avatar
I have -1.5 in the fronts and -1.0 in the rears. Everything seems to be wearing evenly so far. I also try to keep the hot tire pressures in the 36 range (cold around 32).
Old 06-20-2007, 09:40 PM
Z06 Bob
Z06 Bob's Avatar
Thanks for that info. I switch back to my GoodYear F1's for street after a weekend at the track. Any suggestions for getting back to street alignment easily without going to the alignment shop every other week?
Old 06-20-2007, 10:43 PM
C6400hp
C6400hp's Avatar
Mark your street alignment settings on the coencentrics with a paint pen then have them do a track alignment and mark those settings with a different color.
Old 06-21-2007, 04:27 AM
DREGSZ
DREGSZ's Avatar
I like track alignment settings on the street. The car handles much better that way. for Toyos, you gan't get enough neg camber in a vette. I ran them w -4* in my Z28 racecar, maybe it was even more, I can't remember anymore
Old 06-21-2007, 04:47 AM
bobmoore2
bobmoore2's Avatar
Just between us Bobs,
I've been running Toyo RA-1's on the track, and Kumho MX's on the street for about 8 months now. I have about -1 degree rear camber and about -1.5 degrees front camber. I just keep those alignment settings all the time, and I haven't noticed any significant wear problems on my street tires. I expect you'll see the same things with your Goodyear F1's.
If you really want to be crawling under the car frequently to change the alignment, then knock yourself out. But I don't think it's worth the trouble.
Bob
To Alignment with Toyo RA 1 Tire
Quick Reply: Alignment with Toyo RA 1 Tire
