Anyone else remove the oem rear hood seal when on track?
Old 06-22-2007, 01:55 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Anyone else remove the oem rear hood seal when on track?
Even w/ a stock hood it still gives the air somewhere to go. Anyone else do this? I have a DRM vented hood, but I figured more is better.
Old 06-22-2007, 03:22 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
The WC guys that actually went to the wind tunnel (I was never invited) said that the cowel is acually a high pressure area, and you may end up actually pumping more air into the engine bay. This is only word of mouth, but that is what the guys at 3R (the hot Corvette team back in 03') told me they found at the tunnel.
Old 06-22-2007, 03:26 PM
B-ras
B-ras's Avatar
Which was the whole principle behind "cowl induction," right? Still, I would think that any airflow increase under the hood would help. If air goes in there, it must come out somewhere.
Old 06-22-2007, 03:47 PM
Cobra4B
Cobra4B's Avatar
Hmmm... I did notice the hood buffeting at speed... even w/ the vented hood.
I'm going to leave it in next tack event.
Old 06-22-2007, 03:56 PM
Solofast
Solofast's Avatar
If you open the cowl, and it is a higher pressure area than under the hood, air will go in there. While it would cool down the fire wall area it will raise the pressure under the hood and will increase front end lift and reduce air flow through the radiator.
If you have a vented hood, it will circulate air from behind the hood and also reduce the flow of air from the radiator...
Not a good idea at all...
BigMonkey73 (09-10-2019)
Old 06-22-2007, 03:57 PM
Cobra4B
Cobra4B's Avatar
^ Gotcha... leaving it in from now on.
Old 06-22-2007, 04:18 PM
davidfarmer
In a best case scenario, you would have a completely sealed engine compartment, with only Radiator air coming in the front, and then being evacuated directly out through a louvered hood. Of course, in the real world air spills out under the engine, out of the fenders, etc etc.
To Anyone else remove the oem rear hood seal when on track?
Quick Reply: Anyone else remove the oem rear hood seal when on track?
