From drag race to road race..........ready
Old 06-25-2007, 07:43 AM
Allthrottleandsomebottle
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Default From drag race to road race..........ready
Got the car ready for VIR next week
Took it out Sunday(after fixing this little issue http://forums.corvetteforum.com/show....php?t=1740081) to .....uh............er..........scrub the tires and fill up the tank Just about dead hooks at WOT so I may have a little fun
Each weighs 42 lbs.........turn in feels great and quick
Got the Toyo RA1s on the HREs as well to ward off the rain..........
HRE 18 x 12 545 w/new Toyo Proxes RA1 335/30ZR18 & TPS, 58.4 lbs
and the fronts HRE 18 x 9.5 545 w/ new 275/35/18 BFG KDWs & TPS, 52 lbs
See ya'll there............
Old 06-25-2007, 07:45 AM
AU N EGL
AU N EGL's Avatar
WOW you must be some kinda SPEEDIE RACER TYPE.
Old 06-25-2007, 07:58 AM
Cruise-In V Veteran
NCM Ambassador
No............just more tires/wheels than cents…….literally now
Looking forward to your steak Tom?
Old 06-25-2007, 09:01 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Gonna be interesting road racing w/ a stalled auto But then again you've got the bigger trans pan etc now so you should be good right?
Old 06-25-2007, 12:40 PM
varkwso
varkwso's Avatar
he just never needs to get below the stall speed rpm....
Old 06-25-2007, 02:50 PM
Adam Boca
Adam Boca's Avatar
Location: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
but the rear end is not black, is there a problem?
Old 06-26-2007, 07:27 AM
Cruise-In V Veteran
NCM Ambassador
Never had any tranny temp issues..............at CMP or else were. With 2 coolers and a deep pan and I always down shift
Tuning does that Adam
To From drag race to road race..........ready
Quick Reply: From drag race to road race..........ready
