problem with cooling ofpower steering fluid
Old 06-28-2007, 02:59 PM
drbenne
drbenne's Avatar
Default problem with cooling ofpower steering fluid
I have been having problems with the power steering fluid overheating and overflowing the reservoir since I have owned the car. It is a '01 zo6 and I run gm synthetic powersteering fluid. I have recently replaced the rack and pinion and hoses. It has the factory cooler.
any ideas on how to improve the cooling?
Old 06-28-2007, 03:05 PM
Falcon
Falcon's Avatar
It won't help the cooling, but it will help the overflow. Try putting less fluid in the resovior. That was recommended to me and it kept the fluid from puking out.
Old 06-28-2007, 03:59 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Maybe try redline SYN fluid? I've never had a problem. Can you overdrive the PS pulley to slow the pump down?
Old 06-28-2007, 04:11 PM
drbenne
drbenne's Avatar
I have heard of people doing this, but really doesn't seem like slowing the pump would necessarily improve cooling. I would imagine there is some pressure regulator that limits the pumps output as RPM varies and therefore, changing the pulley ratio wouldn't affect the pump output.
Old 06-28-2007, 04:21 PM
Cobra4B
Cobra4B's Avatar
I've always heard that overspinning the pump is what makes the fluid overheat.
Not sure though... never had an issue... have stock Z06 PS cooler.
Old 06-28-2007, 04:24 PM
Feffman
Feffman's Avatar
We've had the same problem in the CTS-V. Cooler is too small. We have two choices:
1) Go to larger cooler from Summitt.
2) Flush using Red Line power steering fluid.
I went with #2 and no problems.
Feff
www.MVPTrackTime.com
Old 06-28-2007, 06:41 PM
AMERICANMUSL
AMERICANMUSL's Avatar
Cooler switch definately...IMO that thing is so inefficient. I would switch to a turn-one pump first however, then try a cooler...I went to a narrower deeper MOCAL.
Old 06-28-2007, 07:38 PM
Kinkajou
Kinkajou's Avatar
I just got a pump from "Turn-one steering". They modify more than 50% of Nascar racecars so they have a lot of experience.
They modify the pump so the output is less, thus lowering temperature and friction on the pump. And that would correct vette problems.
I am still waiting for pressure hose to take the Vette for a spin and take it to a Track day. By the way I have a 94 with an LT1 engine so maybe there is a new solution for your pump.
It is supossed to correct the problem with steering. So maybe you should give them a call and see if they can help you.
Old 06-28-2007, 07:59 PM
joemoia
joemoia's Avatar
Roy
Call the guys at Turn One
http://www.turnone-steering.com/index.html
I talked to them and they explained how their pumps work vs. the OEM pump to alleviate fluid overheating. I don't know if you can use their pump in T-1 class
Old 06-28-2007, 09:16 PM
varkwso
varkwso's Avatar
Originally Posted by joemoia
Roy
Here is another vote for the Turn One option..
Old 06-28-2007, 09:33 PM
ErnieN85
ErnieN85's Avatar
Slowing the pump does help. the bypass (pressure regulator) is an internal bypass and does heat the fluid.
I think that is one thing that makes the turn one pump such a good idea.
for on track (high rpms) it's turning plenty fast!
Old 06-28-2007, 10:01 PM
AMERICANMUSL
Roy
Oli runs one!!
Old 06-28-2007, 10:22 PM
73-84 IMSA Widebody
73-84 IMSA Widebody's Avatar
Just FYI, KRC racing pump and return side external cooler, no problems.
Old 06-29-2007, 08:39 PM
StArrow68
StArrow68's Avatar
Another poss., I had PS issues and thought it was the fluid level. Turns
out my external oil cooler line (SS) had rubbed one of the PS (alum)
lines but not enough to leak, just thin enough to seep under pressure.
Might check tubes to and from cooler.
To problem with cooling ofpower steering fluid
Quick Reply: problem with cooling ofpower steering fluid
