C4 Koni (Yellows) and ES Bushings
All,
Has anyone pressed out the lower shock bushing that comes on the C4 Yellow Koni Sport single adjustable shock and pressed in a energy suspension bushing to replace? If so, which Energy bushing did you use.
I got my ES bushings from DRM and we found that the upper bushing was too big to fit the Koni shock, and have ordered alternate (shorter) ES bushings for the top. The ones we have for the bottom of the shock appear to fit and are tagged with "8064" on the bushing surface.
Just want to know if others have tackled this before pressing out the lower shock bushing only to find that we don't have the right parts. Furthermore, is this swap even worth the time (the lower shock bushing)?
Thanks,
Ron
Thanks,
Ron
Ron
