5-Point Harness Mounts....
In my C5Z I used the Brey-Krause harness bar and Simpson belts. The shoulder belts loop around the bar and the lap and anti-subs go the anchor bolts behind the seat. There is a cross-member under the floor boards to anchor to, the same piece that the seat is bolted to in the rear.
Watch the placement of the bolts so that the seat clears when moved back. Your shoulder belts should have a sternum strap and buckle unless you have pass-throughs in your seat back.
