New lap and sub bellt bar from Hardbarusa/Vetteworks
Old 07-08-2007, 07:07 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Default New lap and sub bellt bar from Hardbarusa/Vetteworks
We are proud to offer the best lap and sub belt bar on the market. It solves all the issues for C5's and C6's. It is a joint effort of Hardbar and Vetteworks and offers a solution for everybody regardless of what harness bar you have. Wow, imagine two Corvette vendors actually cooperating for the benefit of all…what a concept! The bar is laser cut steel, with custom inserts for the eyelets. It offers full seat travel, clip in lap belt attachments, and positions for your sub belts. It requires no modifications, simply lift the rear of your seat, drop it in, re-attach the stock nuts, attach your belts and you are done. And as a $25 option you can now use it with other brands of harness bars that have down tubes or struts. For the users of BK, RD, bars etc, you now have a proper lap and sub belt mount with the pickup points at the correct angle and position. To do this, we use one of our custom 17-4 PH stainless steel thread adapters that are used with our seat rail kits that are used as a substitute for the nut. Now the foot on the end can go over the stud extension and with the provided washer and nut you are done (the foot hole needs enlargement to 14mm dia.) The lap bet bar is powdercoated black for $150 each side and the stud adapter is $25 each. Available from Hardbarusa.com and Vetteworksonline.com
Old 07-08-2007, 07:15 PM
PA Z06
PA Z06's Avatar
Great idea, I wish you had this before I drilled holes for my belts.
Old 07-08-2007, 08:12 PM
ghoffman
ghoffman's Avatar
If I knew how to release products in the past, I would be very rich!
Old 07-08-2007, 08:56 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
nice setup
Old 07-08-2007, 10:20 PM
fcarga
fcarga's Avatar
Nice job, Gary, and at a good price!
Old 07-09-2007, 04:50 PM
ghoffman
ghoffman's Avatar
Thanks, but it was only partly me, Dan Haggerty at Vetteworks gets equal or more credit. It was truly a joint effort.
Old 07-09-2007, 11:02 PM
fcarga
fcarga's Avatar
Well then, kudos to both organizations!
Old 07-10-2007, 12:14 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
Nice job Gary. I am going to call you tomorrow because the sport seats are coming out and I am going with race seats. I like to have a few ideas from you to see what I can fit with your rails.
thanks
Bob
Old 07-10-2007, 04:22 PM
z060ntrack
z060ntrack's Avatar
This works for the sub belt how?
Old 07-10-2007, 09:38 PM
ghoffman
ghoffman's Avatar
You bolt the subs (6 point)to the two holes with the provided bolts.
To New lap and sub bellt bar from Hardbarusa/Vetteworks
Quick Reply: New lap and sub bellt bar from Hardbarusa/Vetteworks
