Moving the rear cradle.
It appears that my rear cradle is off center about 1/8th of an inch and for rear alignment purposes I thought I'd move it over. There are 4 bolts holding it to the frame. But there appears to be locating pins next to the two rearward bolts. I thought it was just a matter of loosening the 4 bolts and whacking the cradle over. The pins are not going to let that happen.
How do I do it?
How do I do it?
you'll need to grind the pins down, or at least grind the 1/8" off of the side you are moving from. The bolts are pretty long, so drop the cradle down as far as you can and see if you can get clearance to the pins. If not, you'll need to drop them down onto jack stands/jack, etc. Don't go too far or your engine will hit the fire wall and/or the torque tube will hit the panel between it and the exhaust.
You could also open up the holes the pins go into...either way will work.
There's an easier way to get more negative camber than moving the cradle... You can get another 1.5 degree of negative camber on any corner of a C5 by removing the spindle from the upper and lower 'A' arms, removing the hub/bearing assy and angle milling the bearing mount face. Don't forget to mill the caliper mount holes the same amount.
I have done this on my road race C5 on the right front and right rear spindles and it worked great...
Shirl Dickey
Shirl Dickey
How does this roll pin work? What is a roll pin? Do you just cut off the existing pin, relocate the cradle the drill a hole and somehow drive in a new pin?
Shirl Dickey
Shirl Dickey
When you suggest grinding the pins down are you saying removing them altogether? And just letting the clamping force of the 4 studs and nuts do the job?
Former Vendor
http://www.engineersedge.com/roll_pin.htm
This is about the most information I have ever seen on a roll pin
The stock pins can be knocked out of the cradle incase you need to put it back to stock.
After you get it in to position and tighten down. Take out your drill and find a flat spot. Mark your spot and start the drilling. It goes pretty easy until you hit the steel chassis. Then tap the pin in to place. If you ever remove the cradle again use the same holes again.
If you are worried about the cradle moving around use both. Do the farmer trick and our trick. Then you will be double covered we do that on cars with big power and slicks.
Randy
Randy
[QUOTE
[/QUOTE]
So the stock pins are just pushed in from under and don't have some kind of bolt or collar above. So, in any case I could just pull it out or twist it out?
[/QUOTE]
