C4 Power steering?
Old 09-16-2007, 06:03 PM
KCHOTBOAT
KCHOTBOAT's Avatar
Default C4 Power steering?
For the second weekend I've cooked my power steering fluid/pump during autox. Has anyone replaced the stock cooler or add a second one. Also how much do the turnone pumps run?
Old 09-16-2007, 07:05 PM
Mojave
Mojave's Avatar
I would just get a Turn One pump and then be done with it. I know a lot of f-body guys who run that with no cooler with great results. I think the pump is around $225.
Old 09-16-2007, 07:15 PM
Z06_BluByU
Z06_BluByU's Avatar
IS this typical for all C4's that track?!?! How long are you running it before you cook it... IT sounds like they should last longer than that!!
Old 09-16-2007, 08:24 PM
djvett
djvett's Avatar
I put a aftermarket auto trans cooler in front of the radiator on mine and the overheating problem is gone. My son and I both drive the car and we make a lot of runs in multiple event weekends.
Old 09-16-2007, 09:32 PM
forsolo2
forsolo2's Avatar
Are you trying to stay legal for scca A-stock?
Old 09-16-2007, 09:34 PM
KCHOTBOAT
KCHOTBOAT's Avatar
No I am not. I ended up in BSP last year because of the wheels.
Old 09-16-2007, 10:05 PM
c4cruiser
c4cruiser's Avatar
I've seen some small power steering coolers that will easily fit where the factory Z51 cooler would fit. The small auto tranny coolers work fine too.
That, along with some Red Line synthetic PS fluid, you should be fine with a good quality stock pump.
Old 09-17-2007, 10:00 AM
WNDOPDLR
WNDOPDLR's Avatar
Fluid can make a difference. I do not run a cooler on my 88 track car and have never had a problem. I use the NAPA power steering fluid and drive fairly hard. I know some folks are using ATF and I think that may be causing some problems.
Old 09-17-2007, 12:24 PM
STEVEN13
STEVEN13's Avatar
Underdriven crank pulley and Redline...no issues at all!
Steve
Old 09-17-2007, 04:54 PM
Solo2GS
Solo2GS's Avatar
St. Jude Donor '07
The cooler is not the main issue, it is a poorly design pump on the C4. I have a factory PS cooler and on long auto-x course and even worse a road course the PS just doesn't cut it.
Old 09-17-2007, 05:27 PM
KCHOTBOAT
KCHOTBOAT's Avatar
The last few autox have been long. I have had 315 on the front for three events the first one short and the last two long and higher speeds. I do agree about the design I really don't like the fact the pump is right up against the motor.
Old 09-18-2007, 02:32 PM
MarkBychowski
MarkBychowski's Avatar
Turn one rebuild is $100 (plus $15 if you want a -6AN fitting installed). I just got mine back. Picked up a rebuildable core for $35 from vette-to-vette so I didn't have to lay the car up.
Old 09-19-2007, 06:51 PM
RickF
RickF's Avatar
I had Turn One rebuild my pump (94 6spd). I just got back from a Watkins Glen HPDE with no problems. My brother and I share the car and ran back to back sessions with no problems for the first time ever. We used Valvoline Synpower fluid.
Old 09-19-2007, 08:47 PM
jpobrien
jpobrien's Avatar
I had several ps o-ring blow-outs at track events until I got the Turn One rebuild. Good for about two years now (touch wood, as David Hobbs would say).
Old 09-19-2007, 10:53 PM
Z06_BluByU
Z06_BluByU's Avatar
link to turn one?!?!?
Old 09-19-2007, 11:04 PM
Mojave
Mojave's Avatar
http://www.turnone-steering.com/
Old 09-23-2007, 12:06 PM
c4cruiser
c4cruiser's Avatar
Can Turn One rebuild the early C4 pumps? My 87's pump works fine for autocross but the last track day I did, it got pretty noisy even though there were no problems with steering. It's the original pump so I figure it's due for some sort of "revitalizing"
I run Red Line PS fluid but no cooler. I swap out the fluid each year to make sure it stay as clean as possible.
To C4 Power steering?
Old 09-23-2007, 12:19 PM
mrc24x
mrc24x's Avatar
Another happy Turnone customer here.
315's, no cooler, syn fluid, no problems.
Old 09-23-2007, 06:14 PM
Aardwolf
Aardwolf's Avatar
I've been doing that as well. The pump is still hanging on.
Old 09-27-2007, 11:09 AM
Kinkajou
Kinkajou's Avatar
After some problems with the p s pressure hose and PS pump I decided to try Turn One and I can tell you that it works great, no more problems.
One less worry at TD's.
Quick Reply: C4 Power steering?
