Battery box for car trailer
I just picked up a winch for my car trailer and I want to install a battery box to hold a deep-cycle battery. But it has to be big enough to hold the solenoid for the winch (2"x3"x3"), the connector for the winch operating cable and a power outlet for my 12v air pump or a 12v drop light. It's going to fit on the front frame rail or tongue, just havent figured out the final position.
Anyone ever built a box from light steel or aluminum plate stock or would it be easier to buy something like a marine battery box that's big enough to hold everything?
You might consider this setup, the box is molded hvy plastic. Got it at Tractor supply for about $90.00. The winch battery is inside in a plastic batterybox I got from Walmart. all of the winch components are in it and the winch remote plugs into the side of it. Plus you can carry all of you trailering supplies and extras. JD
I just charge it before each trip and that works fine. I also have a small solar panel to charge it in the pits if I need it. but I have never used it. It only operates the winch. I was told if you try to hook it to the car you have to have some kind of regulator to charge the battery. JD
set it up so the tow vehicle charges it. I have a small breakaway battery and it is charged by the tow vehicle. Small solar chargers work good for to maintain it when you leave it for a few weeks,
