Advice on Replacement Springs
Old 09-22-2007, 05:34 PM
jeanlucpicard
jeanlucpicard's Avatar
Default Advice on Replacement Springs
I have a 2001 C5 convertible that I have removed the F45 shocks and replaced with Bilsteins. Also, the suspension has been lowered about 1 inch on the OEM bolts - no bushings have been cut.
My wife and I autocross the car about 4 or 5 times each year and take 3 or 4 road trips (about 3,000 miles each) annually so ride quality is important.
I have installed a set of OEM Z06 sway bars with the aluminum end links.
The car now has about 87,000 miles on it - we just finished a plant tour in BG, Kentucky and it was a blast!
I was looking at the VBP Extreme springs but was wondering what you autocrossers would advise.
Appreciate your time.
Old 09-25-2007, 10:18 AM
Carolina C4 Racer
Carolina C4 Racer's Avatar
I would think that the "extreme" springs would be too harsh for a 3000 mile ride but I'm sure that VB&P could recommend a spring that is better than stock for auotcross w/o sacraficing too much in ride quality.
Good luck
Old 09-25-2007, 11:51 AM
asp04
asp04's Avatar
I would go with stiffer swaybars and postpone the springs.
Old 09-25-2007, 12:02 PM
J.R.
J.R.'s Avatar
Default Springs
I went with Z06 springs, sway bars and 04 Z06 shocks and am very happy with driveability, performance and cost of swap.
To Advice on Replacement Springs
Quick Reply: Advice on Replacement Springs
