Michelin Pilot Sport Cups
Old 09-24-2007, 07:01 PM
BIG SURPRISE
BIG SURPRISE's Avatar
Default Michelin Pilot Sport Cups
I have a 2007 Z06 that i run at Sebring 4 or 5 times a year. I'd like to have a second set of tires and rims for these times that i can drive to and from the track, maybe 150 miles round trip. Anybody running these in 295/ 30/18, 305/30/19 on stock rims?
Old 09-24-2007, 08:23 PM
American Power
American Power's Avatar
The 305's will be over stretched on the stock rims. I bought a set of CCW C10's in 18's all around. Enough for many tire options, lightweight and can clear a BBK upgrade.
I ran Toyo RA1's. They performed great. I drive to the track on them and have 4 track days on them so far. I'll probably get 4 more out of them before there done.
If you don't want to invest is new rims, Hoosiers are the only tires that are made in sizes that are adequate for the stock wheels.
Old 09-25-2007, 05:11 AM
BIG SURPRISE
Default Tires
Looked back on Michelins site, they have a 345/30/19. Will they rub? I'd like to stay with stock rims if i could
Thanks, Tim
Old 09-25-2007, 08:24 AM
jittrbugg
jittrbugg's Avatar
Thanks, Tim
You can run 345 on the car. We put it on 18x13's without a problem.
Melissa
CCW
Old 09-25-2007, 04:54 PM
American Power
Thanks, Tim
Really?? Link...
Old 09-25-2007, 07:18 PM
BIG SURPRISE
Michelin-us.com Hit car,van,pickup&suv. On the left side it says tire by name. Look for pilot sport cup. Look under specs.
Old 09-25-2007, 08:45 PM
snitz
Support Corvetteforum!
snitz's Avatar
I'm running Pilot Sports cups on 18" CCW Corsairs. rim widths: 11" fronts, 13" rears, tire sizes 295 front, 345 rear
Old 09-25-2007, 08:56 PM
kentz06
kentz06's Avatar
I used the exact set-up with good results. I am now trying the Hoosier R6...
Old 09-25-2007, 10:31 PM
Swiftwater Z06
Swiftwater Z06's Avatar
Just curious - when running 11" fronts and 13" rears on the track do you run in Competitive Mode or turn off both AH and TC?
Old 09-25-2007, 11:59 PM
snitz
snitz's Avatar
I turn off active handling and do not run in compet mode. I have big understeer issues when active handling comes on when I don't want it.
When you start to push the car, AH isn't your friend.
Old 09-26-2007, 11:55 AM
TeddyFreddy
TeddyFreddy's Avatar
It was discussed here that MPSC in OEM sizes for C6 Z06 will come in 2008. These MPSC are already OEM fitted to 997 GT2 and some Ruf cars.
So far you can use PS2, the 345 will fit fine as they are not really as wide as the number says. It was even found that the contact patch is the same as the GY 325.
I would not bother with PS2. Wait for MPSC.
Old 11-05-2007, 06:12 AM
Yaroslav
Yaroslav's Avatar
TeddyFreddy which would you advice MPSC or TOYO R888?
Old 11-05-2007, 06:59 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
I have both the MPSC and the Hoosier R6, both on 18 inch CCW Corsairs (11 inch front, 13 rear). There is no comparison in grip, the Hoosiers are far superior for track use, but are not street tires, the MPSC' are. I use the MPSC for street tires and the Hoosiers on the track. The 345's in the rear fit, but I had a slight rub at max bump so I slightly trimmed the lip on the inside of the rear fender with a belt sander. They both are near stock diameter ratios so the computer is happy. I think David Yu has had some issues in this regard with his Toyo 888.
Here are the MPSC's at max bump:
and here are the Hoosiers:
Old 11-05-2007, 07:12 AM
Yaroslav
Yaroslav's Avatar
Thanks for answer Garry. One more question is MPSC good for drag racing?
Old 11-05-2007, 07:35 AM
ghoffman
ghoffman's Avatar
I really do not know, I don't do drag racing. They have very little voids (grooves) and are basically close to slicks, and are definitely NOT rain tires.
Old 11-05-2007, 08:27 AM
tmak26b
tmak26b's Avatar
nope, they require too much time to heat up.
Old 11-05-2007, 08:34 AM
TeddyFreddy
Sorry, I don't have first hand experience with any of them.
I can give you some numbers crunching only: MPSC have 80 threadwear, R888 have 100. That means MPSC are softer and should have more grip.
Also I would prefer to stay with the stock sizes which will be possible with MPSC next year (325/30R19).
Another thing from Toyo.com: "tires stored and operated at sub-freezing temperatures, i.e., at or below 32°F (0°C), will lose rubber compound flexibility and may experience cracking when operated under such conditions. Do not move a car that is in storage with these tires, as the tires may crack."
Probably this warning applies to any very soft compound tires, just FYI.
Old 11-07-2007, 06:14 PM
Blue Angel
Blue Angel's Avatar
Originally Posted by TeddyFreddy
...from Toyo.com: "tires stored and operated at sub-freezing temperatures, i.e., at or below 32°F (0°C), will lose rubber compound flexibility and may experience cracking when operated under such conditions. Do not move a car that is in storage with these tires, as the tires may crack."
I'm still driving my '02Z with Nitto 555 RIIs (wear rating 100) and the temperature here (GTA) has been around freezing a few times while on the road, no cracking. I would assume you'd need to have the tires FAR below 0C/32F to cause cracking, but they probably just want to cover their asses if anything were to happen with someone driving their tires in -40C weather... not that you would!
I'm interested in the R888s as a possible replacement for my RIIs next year. EXTREMELY happy with the RIIs on my '02Z (285/35-18 front, 305/35-18 rear), everything from wear to noise to wet weather performance is outstanding... just be careful in heavy rain or on rutted roads with standing water. I'm happy with the RIIs, but would maybe look into the Toyo R888 also if it looks to be a favorable competitor.
EDIT: At 25.8" tall front and 26.3" tall rear, this tire combo would likely work well for the C6Z also if anyone needs a tire with more grip than the GoodYears and still works OK in the wet.
To Michelin Pilot Sport Cups
Quick Reply: Michelin Pilot Sport Cups
