Kumho Question for RASRBOY(Aaron)
Aaron, if it is not proprietary, what is the minimum radial dimension between the bottom of the grooves and/or wear depth indication dots and the exterior cords of the V710 tire? Also, is there an underlayer of rubber between the functional tread and the tire body, if so how thick is it? If you are unable to provide the info, I absolutely understand.
I am only interested as an engineer using the V710's and I agree with everyone who has told me "wear them until the cords show" and " they are worthless from being heat cycled before the rubber wears out" so no need for others to post those already valid comments.
You have a PM!
Thanks for the prompt reply Aaron. Good luck on the job and have fun at LeMans next year. I have come to my personal conclusion that I should "wear them until the cords show."
