Will a 325-19 Hoosier fit rear of a C6?
Old 10-01-2007, 06:05 PM
High 11s
High 11s's Avatar
Default Will a 325-19 Hoosier fit rear of a C6?
Hi there,
Has anyone tried to fit a Z06 size rear Hoosier R6 for track use on the rear of a regular C6 for road racing?
I know the 275-18 will fit fine when installed on a 18 x 9.5 wheel on the front.
If so what wheel did you use?
Thanks!
jdm
Old 10-01-2007, 06:38 PM
Blitz_
Blitz_'s Avatar
I think you willl have rubbing issues. You need the flared fenders.
Old 10-01-2007, 10:08 PM
High 11s
High 11s's Avatar
I think you are correct, I have seen a couple posts with Z06 rear tires on a base C6 with CCW wheels I think. So for street use its likely OK but on the track I am not sure.
Most of the track folks use 18 inch wheels all around I think.
To Will a 325-19 Hoosier fit rear of a C6?
Quick Reply: Will a 325-19 Hoosier fit rear of a C6?
