This is what I was greeted with tonight when removing the LF wheel, my rig up oK?
CI 3-5-6-7-8 Veteran
Not sure how this happened... I guess this is the bumpstop. I zip-tied in in place for now as I'm running VIR this weekend.
Before my last track event I noticed the blue dust boot was out of it's slot and had dropped down. At the time I didn't realize that meant the bump stop was out of place. I just slid the blue boot back up and went on.
I'll be getting new shocks or going nuts w/ coil-overs soon as these have 40k on them now.
Former Vendor
You have to remove the top nut and pull the top bushings out. Then you will see a small c-clip on the shaft. Remove that(pain in the Azz) then pull out everything on the shaft and replace the bump stop. Sounds like fun right???
Randy
Randy
^ Oh... so then I don't need to buy new shocks... sweet. I have 40k on these. I run 3-6 HPDEs a year... so these might have 9 or 10 HPDEs on them and the rest street miles.
Think it's time to send them to Bilstien for a re-fresh?
