SCCA Solo ASP Rules/Mods Questions
Hopefully some people can answer these questions for me as they related to a car in SCCA solo ASP class:
1. Can you run headers and aftermarket X pipe? (the rules talk about manifolds).
2. Can you run a ported throttle body? Can you do a coolant bypass mod on the throttle body as well?
3. Can you run a short throw shifter (rules talk about linkage so I think so).
4. Can you retune the computer (timing and fuel curves)? Assuming this can be done, are people raising the rev limiter to allow more MPH in a given gear? Can you replace valvesprings/retainers to make the valvetrain sturdier for high RPM use?
What other mods are people running on C5's to be competitve in ASP/
Thanks!
Thanks!
Or... does the engine have to be swapped as a whole?
Otherwise, what safe rev limit are people running the the stock LS1 valvesprings? I have an 01 Corvette.
Thanks for all the help!
Per the backdate/model rule, could you run LS6 valvesprings an retainers since those were available in the Z06? Can I run the Z06 camshaft?
