FOUND: Solution to Oil Being Pulled into the Intake Manifold
Over the past year as I have done HPDE events, I have been plagued by oil being pulled into my intake manifold through the line from the valley cover and the line from the passenger-side rocker cover.
Last Spring I installed a AMW catch can in the line that leads from the valley cover to the PCV valve. With it installed I would find about 1.5 inches of oil the bottom of the can after one day of track time. I would also find that the line from the passenger-side rocker cover to the throttle body would also be wet with oil, and I would consume approximately one quart of oil during the day.
After reading several forum members recommendations, I put together a package that has completely eliminated any oil from reaching my intake manifold:
1) I purchased a set of Smith Brothers restricted oil flow pushrods.
2) I purchased a second AMW catch can and plumbed it into the line from the passenger-side rocker cover to the throttle body.
The following are pictures of the twin catch can package and the inside of the two catch cans after a HPDE day at Grattan. The catch can to the front of the vehicle is attached to the rocker cover. The catch can closest to the cylinder head is attached to the PCV line.
This is a view from the driver's side of the vehicle. Note the small aluminum bracket that holds the two catch cans together and that the inlet of the catch can from the rocker cover line is higher than the outlet at the rocker cover:
The next two pictures are views from the passenger-side of the vehicle:
The final two pictures of a top-view of the catch cans; one with the tops on and the second with the tops off. Notice that the catch can from the rocker cover is COMPLETELY dry and that the can from the PCV line has a small amount of oil in it.
Problem solved.
Problem solved.
I have been running two catch cans as you are now for quite awhile now.
I get almost a full can after one track session in the fresh air line (valve cover to TB or air bridge if you have LS2 TB.
I am getting new engine build starting next week with the Smith Brother push rods too. I'm sure this is what is helping you a lot and hope it helps me too.
But you also have a breather filter on your oil cap and this is venting but also allowin unmetered air in.
You probably have read the threads on this over in tech.
DH
DH
I noticed you have a breather on your oil fill cap. I've been trying to figure out a solution to help alleviate crankcase pressure and have tried that. Do you ever get so much oil/air condensed on that filter that it spills out over the headers?
I've wondered why some cars do this and others do not.
My LS1 Camaro did it(with heads/cam and turbos), my LS1 powered Rx7 did it...but my Corvette does not and I drive it pretty hard.
Not a drop, stock PCV, LS6 intake, and oil cap. Has a cam, headers, etc...but no oil issues.
CI 3-5-6-7-8 Veteran
I have no issues w/ my car... the fresh air line is dry and my catch can catches mayve 1" of oil for an HPDE weekend. My father's '04 get's about 1.5" an oil per day on track.
Seems each car is different.
Try the pushrods. They really help!
