Autopower roll bar/cage
I am looking for installed pictures of the Autopower cage or race roll bar in an 84-96 hardtop vette I want to see where the main hoop sits as I am strongly considering buying one of these kits. thanks
Here is my old ZR-1 right before I sold her. The bar could have been shimmed a little higher, but the way you see it worked well for me.
Ed's sits MUCH lower than my AutoPower Rollbar. I barely had room to fit padding on. It was a TIGHT fit. I can no longer see much of anything behind me. I have about a 4" view that I can see behind me, just above the release mechanism, the rest is hidden by the bar/padding. You get used to it though.
Here's two pictures from another racecar I had. This is the famous Junkyard Dog that Jeff built and he took these pictures when the autopower bar was installed.
I didn't take any pictures when I cut up the ZR-1 though.
Hope that helps you.
Jeff's pictures would indicate that the bar is welder directly to the metal frame. My rollbar came with 3/8" metal plates that had holes pre-drilled to match the rollbar. The plates were welded to the metal frame and the rollbar was then attached to the welded plates with SAE grade 8 or so bolts,nuts.
Mark
hey 94ZR1#444 could you send as many pics as you can of the install and finished product to kowalski340@yahoo.com thanks
