C4 shocks?
Old 10-17-2007, 05:36 PM
Umrswimr
Umrswimr's Avatar
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Default C4 shocks?
'95 C4, non-Z51,.
Shocks are toast. I'm running Koni SA's on my C5 and really like them. Any recommendations for a C4 for street/DE/autoX duty? Bilstein Sports?
Old 10-17-2007, 05:46 PM
Solofast
Solofast's Avatar
All of the serious autocrossers have been using the Koni Sport SA's for years. They are comfortable, last forever, and work great with a stock suspension. Set the rears on full soft and twist the fronts to taste and enjoy.... For a C4 there isn't anything better..
Old 10-17-2007, 07:12 PM
Axelrod
Axelrod's Avatar
yea there is... check out the QA1's
Old 10-17-2007, 07:41 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Hardbar is doing a special on Penskes, with or w/o coilovers.
Old 10-18-2007, 08:35 AM
shotchkiss
shotchkiss's Avatar
I liked the Konis better than the QA1s
Old 10-18-2007, 09:22 AM
ScaryFast
ScaryFast's Avatar
Bilstein. Bilstein. Bilstein...
Call their tech dept. and tell them exactly what the car will be used for. They'll provide a custom valving that will work perfectly for you. All for about $75 a shock.
Then when they go bad, you send them back and have them revalved for about $50 each.
Adjustables are hooey at this level...save your money.
There are about 3 active threads on this topic if you want to read the more detailed arguments...search for shocks or QA1
Old 10-18-2007, 10:31 AM
Sidney004
Sidney004's Avatar
Scary:
You wouldn't happen to remember the rebound/compression specs on your bilsteins?
Old 10-18-2007, 11:53 AM
Umrswimr
Umrswimr's Avatar
St. Jude Donor '05
After I blew out FOUR SETS of QA1's on my C5 (in less than a year), I'll never ever buy another product from them again. They were total crap.
Old 10-18-2007, 02:51 PM
ScaryFast
ScaryFast's Avatar
Originally Posted by Sidney004
Scary:
Not off the top of my head, but I have all of my information at home. Will post later if I don't forget:o
I know years ago we started with the "Sears Point" settings, and I've adjusted a few times since. I know I'm 10% softer on compression in the rears, I just rebuilt them two months ago. I think I'll go even softer the next rebuild to see what happens. I want a little more rear grip.
Old 10-18-2007, 03:13 PM
mrc24x
mrc24x's Avatar
I'm running Bilsteins also. Mine are : AK 1034F 360/135
AK 1035R 540/160
I wish I could give an accurate opinion but these are the only shocks that I've ever run.
Old 10-18-2007, 04:23 PM
ScaryFast
ScaryFast's Avatar
AK 1035R 540/160
Plus he's really slow. I'd look elsewhere
Old 10-18-2007, 04:38 PM
Umrswimr
Umrswimr's Avatar
St. Jude Donor '05
Old 10-18-2007, 04:51 PM
mrc24x
mrc24x's Avatar
Ouch..... sad but true.:o
Old 10-18-2007, 04:53 PM
ScaryFast
ScaryFast's Avatar
(Just in case it wasn't obvious, I was kidding...Matt's fast as hell, I'm glad he's not in my class...and what a beautiful C4)
Old 10-18-2007, 09:34 PM
Sidney004
Sidney004's Avatar
AK 1035R 540/160
Are you running those shock settings with Z51 springs?
Old 10-19-2007, 11:21 AM
mrc24x
mrc24x's Avatar
Sidney, I run VBP extreme springs.
Thanks Scary. Although it's more the car than my driving. Hope to see you in ST2 next year.
Old 10-19-2007, 11:23 AM
ScaryFast
ScaryFast's Avatar
I hope they're all prepared for C4 DOMINATION!
Rob's trying to convince me to do Putnam next weekend but I'm too damn broke. Why don't you bring the red car out and let me drive it?
To C4 shocks?
Old 10-19-2007, 11:25 AM
Aaron Pfadt
Aaron Pfadt's Avatar
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
Just to debunk some of the mystery about 'custom valving'. It is no different than setting an adjustable shock to a specific setting. Just you have to take the shock apart to do it. Adjustable valving costs money (for the complexity), but it doesn't degrade the shock in any other way.
QA1s are a unique animal because they are a twin-tube design versus a mono-tube. The piston areas are smaller, but they allow a larger range of damping adjustment. The adjustments are also on the body because the piston doesn't travel in that outer tube. That is more convenient. Most race shocks are mono-tube, the advantages/disadvantages seem to come out in favor of a mono-tube in race applications.
The main reason that we at Pfadt have adjustable shocks on our coil overs (and soon to be released shocks) is that the adjustment is very valuable. We make fine tuning adjustments to the balance of the car with the damping. It is very similar to small tire pressure adjustments, but with a little more range of authority.
Watch for some Pfadt C4 products to be released soon. Sway bars are coming first followed by some adjustable shocks and potentially coil overs in the future.
-Aaron
Old 10-19-2007, 11:51 AM
Sidney004
Sidney004's Avatar
Scary:
Scary:
I hope you didn't forget.
Old 10-19-2007, 01:09 PM
mrc24x
mrc24x's Avatar
Aaron,
That's great news about new C4 products!! Keep us posted.
Matt Carlyle
NASA #26 PTA / ST2
Quick Reply: C4 shocks?
