Pfadt Coilovers and Sway bar Install
Old 10-19-2007, 04:37 PM
JDIllon
JDIllon's Avatar
Default Pfadt Coilovers and Sway bar Install
Here are some pictures of the CO/Swaybars installed on my 2007 Z06. The install is relatively easy, the toughest job was getting the stock front shocks off, the nuts on top are crush nuts and you have to hold the shaft with a 6MM wrench while turning the nut a little at a time. The whole job took about 8 hours, I called Aaron Pfadt twice and he was a great help with info on the disassembly and the install of the new COs and Sways. I did the entire job with the car up on jack stands and didn't have any trouble at all with the install. I have only driven around the block a couple of times, so I can't really give you any report on the handling, but with the settings at 6 and the sways at the center settings the car feels really planted and very little lean in the corners. If anyone has specific questions on the install please PM, e-mail or call me. More details to follow after VIR Nov. 3-4. JD
[IMG][/IMG]
[IMG][/IMG]
[IMG][IMG][IMG][/IMG][/IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 10-19-2007, 05:09 PM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
but they are upside down
j/k
Old 10-19-2007, 06:12 PM
V8 Juice
Support Corvetteforum!
V8 Juice's Avatar
JD, look great and congrats on self install.
Old 10-19-2007, 07:04 PM
davidfarmer
davidfarmer's Avatar
new sway bar design looks much better than the original style. It works great, but was a bit of a mess to get setup the first time.
See you in a few weeks.
Old 10-19-2007, 07:28 PM
jtkeller
jtkeller's Avatar
St. Jude Donor '07
install looks great! I've been loving mine... I got a lot of "bounce" at 6 and am currently running 12/10. I also stiffened up the front sway a bit from the recommended settings.
Old 10-19-2007, 07:44 PM
C5 XTC
C5 XTC's Avatar
JD: they look great, nice install. Can't wait to see how they do at VIR in a couple of weeks.
C5 XTC
Old 10-19-2007, 11:25 PM
dbratten
dbratten's Avatar
Good Job!
I see the Heim links are different than mine. They look narrower and the lower stud in place of the allen head bolt (like your top) is new, too.
Where did you end up setting your height F&R (fender opening)?
--Dan
Old 10-19-2007, 11:46 PM
Silverton
Silverton's Avatar
Can you comment on how you installed your brake ducts? This was a problem with the original Pfadt sway bars.
Old 10-20-2007, 08:22 AM
JDIllon
JDIllon's Avatar
As you can see the arms are shorter on the new design. They don't interfer with the hose from the plastic duct, however they do touch the bottom of the plastic duct that comes from under the front end. But they just barley touch them and I don't think it will be a problem. JD
Old 10-20-2007, 12:22 PM
LOS ANGELES PI
LOS ANGELES PI's Avatar
I just finished installing mine this AM.
Its an awesome product. I had the original setup and upgraded to the new.
BTW, did you use spacer or washer under the OEM front sway bar bracket to accomodate the fatter busing or did you go with pillow blocks?
Old 10-20-2007, 12:25 PM
LOS ANGELES PI
I just finished installing mine this AM. Aaron and his wife Robin are the nicest folks on the planet.
Pfadt is an awesome product. I had the original setup and upgraded to the new.
Old 10-20-2007, 01:16 PM
Silverton
Silverton's Avatar
Are you using DRM or Z06 brake ducts?
Old 10-20-2007, 01:37 PM
JDIllon
JDIllon's Avatar
I used the stock bracket and the rubber bushing supplied with the Pfadts, it fit in the stock bracket no problem. JD
Old 10-20-2007, 01:38 PM
JDIllon
JDIllon's Avatar
I'm using the stock Z06 ducts with a piece of 2.5in high temp hose out to the rotor. JD
Old 10-20-2007, 01:41 PM
Timz06
Timz06's Avatar
Nice, but JD was already fast enough with the stock stuff!
Old 10-21-2007, 02:40 PM
Silverton
Silverton's Avatar
Do you think that the DRM ducts would work with these new Pfadt sway bars?
Old 10-21-2007, 09:12 PM
LOS ANGELES PI
Hey JD, a pic of that would be nice. How did you connect to the rotor? Also, what slotted rotors are you running and any cracking after track days?
Old 10-22-2007, 08:23 AM
Short-Throw
Short-Throw's Avatar
JD,
You'll love the new handling. Find a place to get the car loose at slower speeds and play with oversteer. The car will be planted longer, but will also give you less warning when it snaps!
You're car will be much better in turn #17 at Sebring now.
Enjoy!
Mike
To Pfadt Coilovers and Sway bar Install
Quick Reply: Pfadt Coilovers and Sway bar Install
