Need Urgent help with Sharkbar Install - Sunday
Old 10-21-2007, 01:42 PM
Poppy's Vette
Poppy's Vette's Avatar
Default Need Urgent help with Sharkbar Install - Sunday
I know this is a strectch but I started an install without checking all my paperwork and I have everything disassembled and went to cut my panels and the template is missing I checked the Vetteworks site and they have install instructions online but not the template.
I was hoping someone might have a copy of the template they may be able to scan and e-mail to me? I don't have a fax machine at home
Thanks,
Paul
Old 10-21-2007, 04:22 PM
JDIllon
JDIllon's Avatar
Thanks,
Paul
I have the patterns if you can get to a fax, sorry I dont have a scanner. But I do have a fax here. JD If you need to call me 772 528 0669 JD
Old 10-21-2007, 04:28 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
I would let you fax it to me and I would scan it but the fax has no carbon in it as it kept sticking. I need to get some tomorrow but it may be a option for someone else to help.
Old 10-21-2007, 04:54 PM
emf
emf's Avatar
JD -- I'll PM you a number to fax to . . . I can email / host from there.
Old 10-21-2007, 06:12 PM
JDIllon
JDIllon's Avatar
Sorry I,'ve been watching NASCAR. I'll try again now, or you can call me at 772 335 8318 JD
Old 10-21-2007, 07:25 PM
Poppy's Vette
I can see you guys are working to help and I really appreciate the effort. It looks like now I will just contact Dan tomorrow and see if he can send it to me.
I've got the brackets installed and everything is ready just to cut the holes, feed the bar through and attach it then get the panels back on.
I did get my oil catch can installed while I waited so the day didn't go to waste.
Old 10-21-2007, 07:31 PM
emf
emf's Avatar
Bah . . . been out running honey-do's, and got a big whopping error on my laptop -- JD, if you're still around go ahead and resend. It should be OK now.
Old 10-21-2007, 09:04 PM
LOS ANGELES PI
LOS ANGELES PI's Avatar
You could also leave the panels out for now.
Most do.
Good luck.
Old 10-21-2007, 11:14 PM
vettedan
vettedan's Avatar
Pcervone,
Be careful, copies do not always delicate correctly. The Vetteworks template has to be perfect or the holes will be off and the grommets will not fit. This is why they're not on the web page. I will send you an original tempete tomorrow.
Dan
Vetteworks
www.vetteworksonline.com
253-223-4968
Old 10-22-2007, 10:39 AM
Poppy's Vette
Originally Posted by vettedan
Pcervone,
Dan
Vetteworks
253-223-4968
Thanks Dan, I knew you'd come through for me. I got your PM too. UPS shows my delivery from you with my other harness and lapbar are due today. Thanks again for the great service.
Paul
To Need Urgent help with Sharkbar Install - Sunday
Quick Reply: Need Urgent help with Sharkbar Install - Sunday
