Ideal Trans And Diff. Gearing
Why Is The Mn6 Trans Better Than The Mn12 Trans For Road Racing ? What Would The Ideal Rear Diff Ratio Be ? I Have A
402 Stroked Ls2 Motor With A Heads And Cam Package In A C6.
Location: If you don't weigh in you don't wrestle Road America
If you know what tire size and RPM's you want to run this is a very useful site.
http://www.f-body.org/gears/
You will have to find the gears for the M6 and the M12 which you can find here.
http://www.rsgear.com/c5.htm
This way you can compair the M6 with any rear gear to a M12 with any rear gear.
Most common set-up I've heard of is the M6 matted with a 3.90 gear, if you compair that to the M12 gear with a standard 3.42 they come out pretty close.
