turning rotors
Fill out your profile so we know what car you drive.
Most stock Corvette rotors don't really have enough "meat" on them to remove scoring or grooves by turning them and still meet the minimum thickness value stamped on them. The FSM does not even recommend turning rotors because of that.
Prices can vary widely for C4 rotors so it isn't always worth turning them. Even for my 87 with stock rotors, I only pay $18 each for Brembo stock replacement rotors. Still stamped "Made in Canada" too. I do have them put on the lathe at the show where I work and have them check for run-out but so far they have never needed truing.
IMHO turning rotors has always been a waste of money. Annular rings don't mean much other than a little less surface area for direct heat transfer. Sooner or later either the pad will conform to the rotor surface or the rotor surface will conform to the pads (think Hawk Blue).
Also, how long do wheel bearings last for a C5 Z with stock tires?
bearings: on streets youll last a long time. Dont fuss with them till you can hear them complaining.
Thanks, Wally. I was trying to put together a regular inspection program for my car during next season. This year it has only seen 3 days (9 sessions total) time; next year more.
For a stock C5 Z right down to the tires, run only 4-6 days per year, are there any other hardware items I should budget time/money/know-how to replace?
