Pfadt Racing Launches C6 Z06 Camber Kit
1 Post
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
Pfadt Racing is proud to announce the latest in our Corvette-specific line up! Camber settings are important for maintaining good tire wear and maximizing your tire grip with the road and our C6 Z06 specific kit is exactly what you need. Retail for the Z06 kit is $350. We also have a C5 and C6 camber kit available for $290.
The plates are Pfadt-designed high grade 6061 aluminum and are anodized for corrosion resistance. All hardware is high strength, zinc plated steel or stainless steel. The shims are Pfadt-designed and built specifically for our kit.
Our kit is the only one with all of the C6 Z06 specific parts you'll need and includes everything for a full alignment set up. It's a well known problem that the factory eccentrics can slip, losing your alignment settings. Not only can that cause a loss of grip, it can wear expensive tires very quickly. Don't let that happen to you!
We want to provide you with the most complete kit available, so we include all of the instructions and setting information that you'll need. Our basic camber settings are here:
These settings are a good starting point, but we're happy to talk with you about your specific needs. Just give us a call.
We will be at the SEMA show for the rest of the week so we'll be short staffed at the office. If Brian (our Business Manager) can't answer a specific question, just leave a message and I'll get back to you!
Aaron
Aaron
