(C6) Service active handling, but the system wasn't even on!!
I wasn't getting too much help on the other boards, let me see if the real racers can help. I have an 05 C6. The car runs and works perfect. I ran into two seperate problems this past weekend that is bothering the crap out of me.
#1 I was playing around in the skidpad, I spun out and lost control. Car stopped but didn't stall. All of a sudden my ABS light came on and the service active handling message came on. The run was done with everything off and the message went away after i restart the car.
#2 I was in the middle of an autox run, the message came on again except this time ABS light didn't come on.
Both times they just seem to appear all of a sudden with the AH/TC completely off, anyone have an idea of why it iis doing that?
Received 8,928 Likes
Bill
If you have the "Active Handling Warmup" message come on, take a loog at the IAT sensor. That connector has a habit of breaking one of the wires right at the connector, and an open circuit is interpreted as -34 F. Next time you have the wheels off, check the wiring at the wheel sensors.
HTH, and have a good one,
Mike
nope, it's not the warmup lamp. it's the service active handling message. as i said, the unit wasnt on nor did i do anything abnormal. i did autox and spin it, but i did it many times prior and after and not seem to get the same effect. ahh traction control sucks
