Anyone have a set of oem control arms w/ oem bushings in them? Want to trade?
Old 11-05-2007, 11:27 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Anyone have a set of oem control arms w/ oem bushings in them? Want to trade?
I'm trying to figure out if there's an "easy" or "cheaper" way to go back to rubber bushings in my Z06. Now that I have a track only ar I'm re-waxerizing my car.
The polys are very firm on the street and do creek some over large bumps.
I may just put some Koni FSD shocks on the car in hopes of smoothing out low speed driving.
In the meantime anyone want to swap control arms? I just had these done a few months ago and have run 2 HPDEs with them in.
Old 11-05-2007, 11:42 AM
Shrek
Shrek's Avatar
Brian,
Give Kienan a call and see if his dad would be interested. His shop # is 547-2888.
Jeff
Old 11-05-2007, 11:46 AM
Cobra4B
Cobra4B's Avatar
Good call
Old 11-05-2007, 12:10 PM
Solofast
Solofast's Avatar
Get in cotact with Raftracer..
He has some stock bushings that were essentially new and came out of cars that were changing to poly bushings, they are easy to reinsert, about 5 minutes per side after you get the arms off...
Old 11-05-2007, 01:04 PM
Cobra4B
Cobra4B's Avatar
Cool... thanks for the heads up.
To Anyone have a set of oem control arms w/ oem bushings in them? Want to trade?
Quick Reply: Anyone have a set of oem control arms w/ oem bushings in them? Want to trade?
