rack and pump
Old 11-07-2007, 08:18 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
Default rack and pump
At WGI my steering rack and pump went. I figure if I have to replace it then I might as well set it up if there is a better solution.
Any suggestions?
thanks
Bob
Old 11-07-2007, 08:24 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
your killing that car
put a huge cooler on it.
Old 11-07-2007, 08:38 AM
jwt1603
Support Corvetteforum!
jwt1603's Avatar
A lot of the guys I run with and myself use TurnOne pumps. I think they rebuild racks too.
http://www.turnone-steering.com/index.html
davidfarmer
davidfarmer's Avatar
I don't know of any rack upgrades, but there is a company that makes upgraded pumps. Falcon (Jody) has one, maybe he'll chime in with details. And as John says, make sure you are running a cooler. I've personally found the OEM cooler works just fine in all of my cars, from 300hp to 550hp.
They do just die eventually....your mileage may vary.
****edit, yes turn one is what I was thinking of****
Old 11-07-2007, 11:21 AM
Wicked Weasel
Doug has that pump. I will use that with C6 cooler. I guess the rack will be GM.
Old 11-07-2007, 12:09 PM
Miaugi
Miaugi's Avatar
Any suggestions?
thanks
Bob
There's a thread going in the general section about upgrading previous year C6's to the new & improved rack '08 version....might be worth you looking at?
Old 11-07-2007, 12:50 PM
95jersey
95jersey's Avatar
Be intersting to hear if it would fit. Motor Trend did a review and said it vastly improved the feel of the car compared to previous generations.
Old 11-07-2007, 01:35 PM
Wicked Weasel
We happen to have a C5 and a C6 on lifts right now. Lets see what is different.
I will let you know.
EDIT:
Will not work. Mounting points are different from the C5 to the C6. Oh well it was a good thought.
Off to call turn one and see what they offer.
Bob
Old 11-07-2007, 04:29 PM
varkwso
varkwso's Avatar
Great pumps - I just added one to the FRC....highly recommend TurnOne
To rack and pump
Quick Reply: rack and pump
