Inboard camera and mount
Old 11-09-2007, 06:47 AM
73jst4fun
73jst4fun's Avatar
Default Inboard camera and mount
Wondering what's everyone using for a camera and mount, shark bar or other types? Thanks......
Old 11-09-2007, 07:54 AM
beerkat
Support Corvetteforum!
beerkat's Avatar
Sony HD40 with I/O Port camera mount
Old 11-09-2007, 09:07 AM
c4cruiser
c4cruiser's Avatar
The Shark Bar is going to be the best bet for C3's If you intend on autocrossing or track days, then a harness bar with lap belts keeps you in the seat and will help to stiffen the car. At that point the ability to mount a camera is a plus.
For a camera, use a MiniDV or even an Hi8 analog tape. The HD and DVD cameras usually don't handle the rough ride and shut down. Do a search in this forum using "camcorder". You will get lots of information on what cameras work best.
Old 11-09-2007, 09:56 AM
Aardwolf
Aardwolf's Avatar
I use mine stuck to the roof with this mount from chasecam.com it works well!
Old 11-09-2007, 02:59 PM
73jst4fun
73jst4fun's Avatar
Thanks guys for the helpfull info, the Chasecam site looks like it has a suction cup mount I can use on the back deck on my vert, a perfect place to mount the camera and they offer extensions.....
Old 11-09-2007, 03:39 PM
Aardwolf
Aardwolf's Avatar
The chasecam mount has worked well for me, plug and play with my camera. My digital cam does video so I use that, there is a tripod mount on the bottom and the chasecam mount just screws into there. I end up having to use movie maker to turn my video right side up though.
Old 11-09-2007, 04:09 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Anyone used this camera?
Old 11-09-2007, 06:13 PM
QwickerRon
QwickerRon's Avatar
I have a JVC with a 30g HD. I can begin recording at the start and everything's fine. My problem is it keeps stopping the record function soon after the start of the run. Camera is on, just not recording. Not sure if it's the jiggling or what.
Old 11-09-2007, 06:34 PM
Z06Norway
Z06Norway's Avatar
Yepp, pretty ok, good thing is you can stick it anyware, no wires etc.
Bad thing, microphone/sound is bad and video is not as good as chasecam.
here is a vid
http://youtube.com/watch?v=jtjLUaGqSaE
Rune
Old 11-09-2007, 09:29 PM
hisvett
hisvett's Avatar
St. Jude Donor '14-'15
here is a vid
Rune
Thanks for the post, I was just about to grab one off of Ebay. Not all that bad of a video for a self contained cam. Sometimes you can wrap the mic pickup area with foam to cut down on the over modulation. Think I'll go for the lipstick cam and plug it into my vidcam.
Old 11-09-2007, 10:01 PM
Tourmgr1
Tourmgr1's Avatar
I checked the link out and in one review I found this comment.
"If you are not going to be using it in water or wet environments all you have to do is remove the mic cover and there is a black square rubber cover over the mic. It is 1mm or thicker and causes the sound distortion and lack of range. Remove it an re-install the cover and you get as good a sound as any other video camera"
Good Luck.
Old 11-10-2007, 01:24 PM
Z06Norway
Z06Norway's Avatar
Good Luck.
great tip, will try that :-)
thanks
Rune
To Inboard camera and mount
Quick Reply: Inboard camera and mount
