A ton of stuff
A ton of stuff
I thought I would put this up 1 last time with a list showing what comes with this car & honestly there is even more than on this list.
Item Number Description Qty Ea Total
New 88895128 C5 Front Caliper 3 $185.00 $555.00
New 88895129 C5 Front Caliper 4 $185.00 $740.00
New C6 Front Caliper 2 $185.00 $370.00
New 12554740 Shift Rod for Trans 1 $0.00
New 26086581 Front outer tie rod end 2 $115.00 $230.00
New 88955488 Rear outer tie rod end 1 $90.00 $90.00
New 88955489 Rear inner tie rod end 3 $65.00 $195.00
New 26055105 Front inner tie rod end 3 $97.00 $291.00
New 10419312 RF Valance 2 $11.00 $22.00
New 10419313 LF Valance 2 $11.00 $22.00
New 10332530 Knuckle LF or RR 1 $183.00 $183.00
New 12570806 Flywheel 1 $600.00 $600.00
New 88967287 Front Bearings 6 $425.00 $2,550.00
New RF Rotors AC - Delco 8 $39.00 $312.00
New LF Rotors AC - Delco 10 $39.00 $390.00
New RR Rotors AC - Delco 5 $39.00 $195.00
New LR Rotors AC - Delco 4 $39.00 $156.00
New Hawk Front DTC pads new 12 $260.00 $3,120.00
New Hawk Rear DTC pads new 6 $240.00 $1,440.00
Used Hawk Front DTC pads new 11 $60.00 $660.00
Used Hawk Rear DTC pads new 6 $50.00 $300.00
New Front Carbo Tech Pad 1 $150.00 $150.00
New Rear Carbo Tech Pad 1 $150.00 $150.00
New Air Filter 1 $13.00 $13.00
New Oil Filter 1 $7.00 $7.00
Used 12570806 Flywheel 1 $200.00 $200.00
New Cases Mobil 1 ATF 9 $42.00 $378.00
New Cases Mobil 1 15 - 50 12 $42.00 $504.00
New Hoosier H - wets set of 4 1 $1,200.00 $1,200.00
Used Hoosier A - 60% - 80% good sets 15 $400.00 $6,000.00
Used Hoosier A - 90% or better sets 4 $700.00 $2,800.00
$23,823.00
Plus 2002 perfect condition ZO6 2006 National Championship car, new engine, new clutch, new trans, new diff (all w/only 20 laps on them), triple adj remote resv motons, carbon fiber hood, 5 sets of rims and all the latest and greatest. This car has still proved to be the fastest C5 T1 car in the nation. All of the above stuff and the car for $50,000.00
Call Lance 810-923-9518
$23,823.00
