Rear spindle nut.
Old 11-13-2007, 01:07 PM
beerkat
Support Corvetteforum!
beerkat's Avatar
Default Rear spindle nut.
I am changing the bushing in the control arms. I need to remove the rear axel spindle nut. I do not have a socket that fits it. Does some one know what size socket it takes. I know it is bigger than a 32mm.
thanks
Old 11-13-2007, 01:13 PM
RAFTRACER
RAFTRACER's Avatar
34mm
Old 11-13-2007, 01:24 PM
beerkat
beerkat's Avatar
Thank you. I guess I should of said it was for a C5Z. Congratulations on your victories.
Old 11-13-2007, 02:23 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
or 1-5/8" i think was the size. I have both there is standard one that works.
Old 11-13-2007, 05:23 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Originally Posted by RAFTRACER
34mm
And a big damn breaker bar.
Old 11-13-2007, 05:28 PM
NoOne
NoOne's Avatar
Its a PITA to find a 34 too.
Napa did not carry them, sears, etc...I borrowed my neighbors 35 which worked great for taking it off but I had to goto a few stores to find a 34 to put it back on with.
Old 11-13-2007, 05:31 PM
John Shiels
NAPA by me had them 34 mm Pile of them not great quality but if it's all you can get it works.
Old 11-13-2007, 11:32 PM
CHJ In Virginia
CHJ In Virginia's Avatar
Auto Zone stores carry them - think that I paid $14.95 for the socket.
Old 11-13-2007, 11:47 PM
vms4evr
vms4evr's Avatar
I found mine at Carquest. The quality is not bad and it is guaranteed. I had no problems loosening the spindle nut at all with a standard breaker bar.
Old 11-14-2007, 09:34 AM
Massc5
Massc5's Avatar
Snap On,
Old 11-14-2007, 09:54 AM
beerkat
beerkat's Avatar
Thanks to all of you. I found one a NAPA for about $15. It is a 34mm impact socket. It is intended for spindle nuts. Apparently a lot of GM and other brands use the same size nut. I broke it loose with just a normal 1/2" breaker bar.
Old 11-14-2007, 07:46 PM
varkwso
varkwso's Avatar
Originally Posted by beerkat
...... I broke it loose with just a normal 1/2" breaker bar.
That is because you are a manly kind of guy...how is the swap going?
Old 11-15-2007, 10:00 AM
beerkat
beerkat's Avatar
Well the front is done. It was pretty straight forward. Not having a press and not wanting to burn the old bushing out I drilled several holes through the old bushings relieving some of the compression pressure making it easier to knock out.
The rear is something else. I have one side apart which took me a few hours to do. That is including trips to NAPA for tools that I need. Not having done this before I think that things are going well. Now if I can remember how it goes back together....
Even though I marked that alignment points on the front the new bushing have changed the alignment some anyway.
Old 11-15-2007, 05:31 PM
varkwso
varkwso's Avatar
Now with a good track alignment you will be sporting!
Old 11-15-2007, 11:52 PM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
next time bring it to my house .i allready have all those tools!!!!
Johnny
Old 11-15-2007, 11:54 PM
racerwannabe
St. Jude Donor '06
my car has been apart so many times..it disassembles itself when i put it on the lift...
Old 11-16-2007, 09:55 AM
beerkat
beerkat's Avatar
Johnny
Thanks for the offer. I am a driveway mechanic. Jack stands and a creeper. Also I am a toolaholic so I do not mind buying tools. It would be nice to have a lift and car that disassembled itself.
To Rear spindle nut.
Old 11-16-2007, 12:26 PM
mgarfias
mgarfias's Avatar
Originally Posted by Massc5
Snap On,
Amen.
I've actually bought two. Once to do my first hub removal and somehow that socket ended up in my dad's toolbox and moved with him. So I bought another.
Life is too short to buy cheap tools.
Old 11-16-2007, 02:58 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
The first time I took off my driver side, I used a breaker bar and my jack handle and picked the car up off the jack stand, so I switched direction and stood on it instead.
Big enough lever, you can move anything.
Old 11-16-2007, 05:12 PM
beerkat
beerkat's Avatar
Or in my case a lot of body mass.
Quick Reply: Rear spindle nut.
