Harness Bar
Old 11-13-2007, 09:27 PM
LT70ZR91
LT70ZR91's Avatar
Default Harness Bar
I am looking for the manufacturer of a stainless steel harness bar that I think was purchased from a supplier in Washington or Oregon. It has hoops to keep the shoulder harnesses from sliding around and came with a fire extinguisher mount. The bar mounts to the stock shoulder harness mounts and heim joint end rods that go down to brackets that were added to the seat mounts.
Any ideas?
Old 11-14-2007, 12:01 AM
rhneff
rhneff's Avatar
Description sounds like Brey-Krause.
http://www.bkauto.com/corvette/index.php
Old 11-14-2007, 10:22 AM
c4cruiser
c4cruiser's Avatar
Year of your car? Coupe or vert? Helps to fill out your profile with car information.
Were you thinking of the SharkBar for C3's?
Old 11-14-2007, 10:35 AM
LT70ZR91
LT70ZR91's Avatar
It is not a BK. As I said it is stainless steel (brushed) and has a built on fire extinguisher mount.
Thanks for your imput.
Old 11-14-2007, 11:09 AM
tcmc5
tcmc5's Avatar
I think you're looking for Speedware Motorsports in the Seattle area.
http://www.speedwaremotorsports.com/
Old 11-14-2007, 11:19 AM
LT70ZR91
LT70ZR91's Avatar
No, not a SharkBar. Not a coupe or vert, a 99 hardtop. Too many toys to list.
Thanks!
Old 11-16-2007, 08:33 PM
LT70ZR91
LT70ZR91's Avatar
ttt
To Harness Bar
Quick Reply: Harness Bar
