Chirping Sound from RR Under Braking
Old 11-18-2007, 02:23 PM
BQuicksilver
BQuicksilver's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Default Chirping Sound from RR Under Braking
I'm wondering if anyone else has had the same issue and can point me in the right direction. 2002 coupe with stock Z51 suspension (plus bilstein sports) and several track days over the past few years.
When I get on the brakes (even street/light braking) the car will usually make a fluttering high pitched chirping sound. The sound almost certainly comes from the RR area. I hadn't made any new changes when it started late this summer. Bumps on braking seem to make the sound louder.
Does anyone have any specific recommendations as to what this could be?
Old 11-18-2007, 03:43 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
I had a similar sound and it was the Bistein shock was shot. Push up and down on the car while stationary.
Old 11-18-2007, 04:22 PM
BQuicksilver
I'd bet you're right John.
Old 11-18-2007, 05:46 PM
John Shiels
Drove me nuts! My regular mechanic not race mechanic solved it in two mintues. My car is so stiff it is hard to even push down which made it hard to diagnose easy.
Old 11-18-2007, 06:14 PM
vetteccrazy
vetteccrazy's Avatar
i have a 2000 c5 with bilstien sport shocks. i have recently heard this noise coming from my right rear. it went away after a few days, but im sure it will come back.
mike
Old 11-18-2007, 06:25 PM
John Shiels
mine came and went in the beginning also which makes you Lubing bushings one at a time tighting everything it drives you crazy!
To Chirping Sound from RR Under Braking
Quick Reply: Chirping Sound from RR Under Braking
